BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Wheelies and spinning off tha line.............. NEW TOPIC NEW POLL POST REPLY
1bad12r
posted August 29, 2003 05:52 AM
I know this probably has alot to do with the way I'm leaving, but you know how it is at tha strip. Nobody wants to help tha new guy get better because he'll be outrunning them later on.
Anyway, my last few trips to tha track I've been either wheelieing just around tha 60ft mark, or spinning. Can this be fixed in tha rear shock adjustment ? Or, is it gonna have to be adjusted in tha rider ?
Help guys ! I really want those 1.55 60 ft's !!!!!
768 Ryderz
posted August 29, 2003 12:26 PM
you can stop much of the spinning by preloading the clutch as you ease into the stage light. After 400 passes finally Kerry told me that (duh!) and it works great.
Wheelies are another issue entirely; even with a 6" arm, I never whupped that problem. What helps is to get so flat on the tank, yr neck hurts to see the last yellow... Tonight I go to the track and see if my new 10" arm helps.
kangpow
posted August 29, 2003 07:17 PM
((((( you can stop much of the spinning by preloading the clutch as you ease into the stage light. )))))))
How do you preload the clutch ?????
wannabe
posted August 29, 2003 08:11 PM
By 'preload the clutch' i think they mean to let the clutch handle out until the clutch starts to grab a little. Some people will do this while others like me increase the freplay in clutch so that it engages just a C-hair from the bar.
posted August 30, 2003 05:39 AM
By 'preload the clutch' i think they mean to let the clutch handle out until the clutch starts to grab a little...
exactly, wannabe! It really takes a lot of the shock outa the system when you throw the clutch away.
krexken
posted August 30, 2003 11:07 AM
Wheelieing downtrack can be lessened by going to a taller gear. It'll probably cost you more in clutch plates in the long run but you should be more consistent since you're not having to back off the throttle to keep the front end down. Some guys here pull the clutch in slightly instead of backing off the gas to keep the front end from climbing any higher.
1bad12r
posted August 31, 2003 03:49 AM
thanks guys !
768 Ryderz
0.21531414985657 seconds processing time
