BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Houston Raceway 12/9 - 1361 results NEW TOPIC NEW POLL POST REPLY
posted December 10, 2001 05:48 AM
great weather if a bit nippy (50's), too many cars, shade tree mechanics oiling down the track again & again, but the forced waits were good for my clutch...
1st pass: 9.283 @ 149.86
last pass: 9.280 @ 150.50
real uneven results in between, but little by little I'm getting used to the 1361/6"arm. Even with my 230lb suited weight, the 1361/arm seems to get me down the track.
I am NOT getting WOT in 1st fast enough, but there is hope for teens, maybe faint hope, but practice - practice - practice...
NINJA12
posted December 10, 2001 10:06 AM
details
Come on man, GIVE US THE DETAILS.
60' 330' 1/8 mph . etc
posted December 10, 2001 10:53 AM
I don't wanna bore you but since you insist
first pass
60' 1.573
330' 4.034
1/8 6.040
1/8 mph 122.37
1000' 7.788
1/4 9.283
1/4 mph 149.86
last pass (9th)
60' 1.576
330' 4.036
1/8 6.042
1/8 mph 122.51
1000' 7.787
1/4 9.280
1/4 mph 150.50
don't let the consistency of these 2 passes fool you, the other 7 were all over the map; i am still trying to figure out what works (e.g. lay over tank on launch), what doesn't (e.g. launch at 5000rpm).
posted December 10, 2001 01:26 PM
Dude that rocks!! man Im jelous that your still racing and im not. but then again my pocketbook needed a break!! especially with christmas coming along! man Im glad your doing so good! hey on your dyno chart how was your air fuel mixture? I made a couple changes to your map. but I first want to know how the air fuel mixture was on the dyno? cool thanks man! Mike
posted December 10, 2001 02:53 PM
Mike, this has the AF on it.
http://bikeland.webasyst.com/board/viewthread.php?FID=1&TID=792
toprat
posted December 10, 2001 03:42 PM
Just curious...What tire are you running? Bike slammed?
1991 ZX-11 Turbo
Too much is never Enough
posted December 10, 2001 04:12 PM
so is that with the Monster snorkel? looks right on but when the ram air kicks. Ill send you the map I tweaked alittle and just give it 3-4 passes and let me know what you think, cool.
MM
krexken
posted December 10, 2001 09:32 PM
That's flying, Karl. Can't wait to see it in person. See ya in March!
posted December 11, 2001 01:32 AM
MM : if you send me that map, I'll blow it in and try it this fri (do 3 passes with my current map then the rest with your tweaked map). Thx a million for helping.
Yep, it does have the snorkle
Oh yah, my battery situation is still a problem for hot lapping. I had to push offa the track last Sun when I stalled it during dry hop. Stocker battery works great when cool but... I know I should be cooling down between passes, but this is not always possible. In 2002 I will run S/ET and P/ET to get more runs. I'd hate to get bumped out because of a dead battery. Since we seem to have hit a dead end trying to find a super battery which fits in the stock slot, I'm thinking of a helper battery (dry cell) which I could put in the trunk, wire it in parallel. Whatta you think?
toprat:
running MT MCR2 tire; am down 2" front & back, will try 2.5" front & back this weekend, but don't want to burn another hole in my undertail.
Krex
you just wait till yrs is motivating. Your skill + svelte figure = 8.9's for sure.
posted December 11, 2001 12:30 PM
I would not run a seperate battery the will probably work agenst each other during charging, Hmmmm.. you know what you can wire in a switch on the spare battery! and then use it for starting only! that way when the oem gets hot you can use the other, I would use the Oddessy battery(FBG), I think that should work well, Ill help you if you need the design, Im working with Interstate to help spark some intrest in developing a new battery for heavy duty starting applications! cool talk with you soon, Ill send that map to you tonight! cya
Mad Mike
posted December 11, 2001 02:21 PM
Mike,
I liked the idea of a switched 2 battery system, but when it occured to me that a battery prob weighs 12-14 lb... yikes! I am going to take out my stocker and see exactly what the possibilities are in that cavity. Do a cavity search! Yeah!
looking fwd to getting the MM-tweaked map. Right now its raining (again) but Fri is supposed to be sunny, time to try out yr map. If you get me to 151mph, I will send you someting tasty from Texas (hint - NOT a Dallas Cowboys cheerleader).
krexken
posted December 11, 2001 07:21 PM
Karl, a 1500cc busa ridin friend of mine has the same problem as you. He installed another battery in his trunk. Not sure how he has it wired but it cured his problem. I'll ask him.
RAC4IT
Bergie
posted December 11, 2001 07:34 PM
what battery
why are you guys having battery problems? mine seems to work fine?
posted December 11, 2001 08:27 PM
bergie, it is because of the added crank from the big Kit in these bikes, more compression to turn over after a few times it is very hard on the batteries, now on your stock motor you will mever notice this problem!
mad mike
posted December 12, 2001 01:11 AM
Bergie,
its only when its very hot; let it cool for 20 min its fine again.
posted December 12, 2001 01:17 AM
Ken, this is a good possibility; but rather than a second battery in the trunk, maybe just put a single, more powerful one in the trunk. Use an Odessy (dry cell) so it could be mounted sideways???????
hmmmmmm???????
posted December 12, 2001 01:18 AM
Bergie,
BA
posted December 13, 2001 08:34 PM        Edited By: BA on 13 Dec 2001 20:37
I aint' stupid, I'm just dumb!!
Alright, I have absolutely NO experience with full race bikes, nor any BB Kaws or Suzi's, but, I do have a question about this starting problem.
Why do you guys say it's a small battery problem?
The frequent mention of heat and cool-down time leads me to think of a weak starter. (not enough torque, frequently caused by excessive heat and high compression, etc.)
So, knowing that an extra battery will 'overcome' a weak starter, I have to ask, has anyone tried putting some kind of heat shield around the starter?
Some heat resistant material around it, and/or a metal shield perhaps?
Just curious.......
Don't flame me too bad, ok?
BTW - Nice runs on the bike man!!! Low 9's!! Wooohoooo!!!
SpencerCyclecom
posted December 13, 2001 09:51 PM
That MUTHA is hauling!!!!
150mph with a 230pd rider YES IT IS MAKING POWER
GOOD JOB!!!!
wok on that shortime and i see 9.0's
Doug
SpencerCycle.com
Doug Ray
SpencerCycle.com
SpencerCycle Center Inc.
Spencer Performance Group Inc.
Toll Free 1-800-510-1945 ext #10
International 1-800-510-1945 ext #11
Local/Tech 1-704-642-0987 ext #12
Fax 1-704-642-0987
NINJA12
posted December 14, 2001 10:09 AM
I'm more inpressed with the 122mph 1/8th.
Good riding on that monster.
posted December 14, 2001 10:22 AM
I am NOT a good or experienced rider, but the 1361 has so much low end hp/torque, that along with the arm, its MUCH easier to ride quickly than stock.
Tonight its back to the track, jack, and see if I can get the low 1.5 60's, 3.9 330's that are needed to get my fat ass into 9-teens.
krexken
posted December 14, 2001 08:51 PM
I had the same thoughts, BA. The starter doesn't seem to be in a particularly hot spot though. Of course, all of the pulling up in line may heat it up pretty good unless he's pushing it. I seem to recall a small gap underneath the starter. Perhaps enough room for some insulation to be wrapped around it.
Here's another idea. Perhaps his static timing is set a little too high at idle. Less timing will make an engine spin easier. Then again, the computer may retard it for cranking purposes. Some high end race car ignitions have this function. You got a PC3R, Karl? Either way, backing off the timing could help you with your problem. I'll bet Doug M could shed some insight on the computer.
posted December 15, 2001 03:23 AM        Edited By: entropy on 15 Dec 2001 03:35
timing - hard HOT startin
Krex & BA:
I have a PC3r and its all 0's anywhere near 0% throttle/1000rpm. I could go minus numbers (retard) at 0-1500rpm, 0-2% throttle?????? you guys think that would help? No starting problem last night,even doing 4 passes pretty much back to back, but it was in 50's.
Last night was perfect weather conditions, but left lane had traction problems down track unless I stayed in a very narrow groove(i sure didn't). Like the gentleman I'm not I gave ZXAlan the r lane all night cause he was determined to get 9.4's in 2001 and last night was his last chance. he did
I got one good pass, my personal best: 9.189 @ 151.44. none of the others were clean. Hey, i'm not bitching that i couldn't back it up, that'll come
60' 1.559
330' 3.982
1/8 5.972
1/8 mph 123.47
1000' 7.707
1/4 9.189
1/4 mph 151.44
ZX12Girl
Adrenaline Junkie
posted December 15, 2001 07:57 PM
You go with your bad self!!!!
Awesome runs....I bet when you get used to that 1361...You'll hit 9.00000 or less!!!!
I am so envious!!!! Your still racing!!!! I'm sitting in about 2" of that nasty white stuff!!!
posted December 16, 2001 01:37 AM
Thx Angi, I appreciate your optimism, but Team Fat Ass is realistic, so 9.000000? possible but not likely, although with a little weight loss and a little hp gain, hmmmmmm
We have no white stuff here and I will miss it on Christmas Day
0.23717594146729 seconds processing time
