BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: a new way (for me) to abuse clutch!! NEW TOPIC NEW POLL POST REPLY
posted August 20, 2003 02:22 AM        Edited By: entropy on 20 Aug 2003 03:23
a NEW way (for me) to abuse the clutch!!
And I thought there were no clutch surprises left...
Pulled my clutch this am and found the OUTER 3 fibers were skinny dark toast (.123-.124) whereas the other 8 fibers are fine (.127-.128). Steels are perfect, only a coupla sm discolored spots.
Go figure???? Usually the INNER few fibers go first, with the other fibers wearing down along with em. When the fibers turn dk brown & get to .125-.126, the steels turn blue, into the trash they go, call Ron Ayers... Its a routine.
I wonder why this time its different???
Maybe its the Muzzy cams??? Bahahahahahahahahahaha!!!!!
posted August 20, 2003 04:03 AM
I would say that would be slipping up on the top end....but that is just my guess.. havent had that one yet.
Mad Mike
ra12r
posted August 20, 2003 05:38 AM
Your cranking compression is too high, it should be around 200psi. That will stop ALL clutch problems!!!
AnotherRedHead
posted August 20, 2003 06:29 AM
Karl, its about time you put an MTC multistage in that thing!
posted August 20, 2003 10:43 AM
I'm thinking it is the 84 pulls on JC's dyno...
It could be slipping on the big end, my mph is down a couple, but 330- 1/8 is OK, et's in the teens, so it maybe has a big end mph fade (152)... The weather was REALLY shitty tho...
As far as the cranking compression. With a bit more base shim and 109/111 cam settings, it's only making 220-225 or so (down from 255-260), and I don't know why that would hurt the clutch??
Nick,
It is indeed time for an MTC multistage, but i'm broke. Anyway, I don't know shit about setting up an MTC. [BTW: REALLY cool turbo you are building]
The 10" arm allows REALLY hittin' it outa the hole. Too bad I only got 3 passes on Sun before rain.
RAC4IT
Bergie
posted August 20, 2003 01:00 PM
check the bearing on the clutch shaft if you notice changes like this
krexken
posted August 20, 2003 02:46 PM
Big race this Suday at Red River, Karl. Great payout and should get lots of practice in too. Glad to hear someone is going down the track.
posted August 21, 2003 01:28 PM
Bergie,
exactly what bearing are you refering to?
posted August 21, 2003 01:30 PM
Ken,
I am supposed to biz-travel on Sun-Thurs, but if that falls thru, maybe I'll come up. Are you racing??
krexken
posted August 21, 2003 02:13 PM
Not unless someone supplies me a ride and I ain't had no offers. They're supposed to have a 9.0 class also. Heads up, pro tree, don't go faster than 9.0. I'm still planning on being there though. Should be some good grudge racing worth watching. I've been working on a friends bike.....
AnotherRedHead
posted August 21, 2003 02:49 PM
Ive setup a couple MTC's so far, they are working perfect. You should hollar at me if you want to get one, I can get you a little discount off retail if you want one.
RAC4IT
Bergie
posted August 21, 2003 05:51 PM
the bearing that the inner hub puller shaft rides on
posted August 22, 2003 11:15 AM
it seems fine... (i hope) but thx for the tip
Ra12r
posted August 22, 2003 05:06 PM
Entropy, that was a joke,,,,,,,,,get it?! 200psi means less HP!!!
posted August 23, 2003 12:58 AM
duh... I'm slow on the uptake (and fat), but at least I'm slow...
0.24140214920044 seconds processing time
