zx12richard
The Green Monster..
posted July 20, 2003 10:38 PM
Sprocket questions????
What sprocket combos are you guys running and times on 6" inch over bikes????? Looking to get an arm and want a sprocket combo to run...
posted July 20, 2003 11:53 PM
17/49-51 depending on what gear you wanna cross the line at.
1bad12r
posted July 21, 2003 01:08 AM
I run 17-49. But I'm gonna try 17-50.
768 Ryderz
kawachan
posted July 21, 2003 07:39 AM
I run 17/46, but I am going to try the 49-51 to see if if will help. 17/48 did not help anything but my 60's at first, but since then I have a 1.493 60 with the 17/46. Getting my rear shock revalved, so maybe I can drop that too!
RED NINJAS RULE!!
Cmarsh93z
posted July 21, 2003 08:50 AM
I weigh alot, so I run a 16/48. I ran a 17/48 for awhile....and it ran simular times, just had to work the clutch alot more out of the hole. BTW, Im 60". With the bike slammed....I can launch in my sleep with minumal clutch slip.....high 1.5's, low 1.60's with average launchs. 1.57 best on a shinko. This is in the 80 degree heat also, so im sure it will improve this winter.
Chris
ProCycles
60" Zx12
DR JOE
posted July 21, 2003 09:30 AM
I ran a 16/46 combo and had very good luck with it...
DR JOE
krexken
posted July 22, 2003 03:41 PM
Blah, blah, run what ya like. I'd suggest a gear tall enough that lets you get wide open in first gear. If your geared too low, you'll be fighting wheelies even at 6 over. Main downside to too tall of a gear is clutch wear and heat. I also ran 16-46 at 6 over and wheelies were still a problem downtrack. Never wore out a clutch though.
