BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Air shifter NEW TOPIC NEW POLL POST REPLY
jus1975
posted June 02, 2003 07:40 PM
Air shifter
I have an '02. And I was wandering if the bridge part of the swingarm, the part in front of the tire, could be used as an air tank. Would it hold enough air. What do you guys think.
ninjamissile
posted June 03, 2003 12:54 AM
I tried to have my stock arm pressurised ages ago but they told me there were to many holes inside the arm to weld up and they gave up.
Ninja Missile
ninja12
posted June 03, 2003 07:23 AM
It can be done with the entire arm, dont know about the bridge .
You would need to find a way to block it off from the arm tubes.
either would hold enough air for a pass.
Bossman69
posted June 08, 2003 01:16 PM
I have an 02 with the solinod mounted on the ram rod with 140psi regulator and 1000 psi in bottle but anything over 9000 rpms and it will not shift?
8.99 @ 162 02 zx12 Gotta Love NOS
ninja12
posted June 08, 2003 04:56 PM
more kill
Bossman69
posted June 08, 2003 06:17 PM
I have put kill tiem until the bike noses over and it will not shift! Any more kill time then that and I might as well foot shift!
hotrodninja
posted June 11, 2003 04:54 AM
By selinoid on the ram rod, are you saying the shift piston is mounted so that it actuates on the linkage, vs. the shift lever? Is it electric over air, and if so is the elec / air selinoid as close to the air ram as you can get it? Max leverage, and min. distance between the elec /air selinoid and ram are critical. Also, make sure you didn't put some sort of filter on the air outlet of the ram. Having a sportbike type kill that ties to the stick coil inputs from the CPU is the best way to get a consistant kill time. I've had trouble when using the common side of the coils. Just a few things to check.
Be consistent, win money.
Bossman69
posted June 11, 2003 09:03 AM
I just had and 24" line and a 6" line made and will try that. Yes, the mount is made by Lee's performance. I got it from Schnitz. The shift piston is horizonal and I had the solenoid mounted onto the shift piston(no line in between) How much closer can I get then that. But I guess it was to close.
hotrodninja
posted June 11, 2003 09:08 AM
I have the same bracket, and mine shifts fine at 130psi. (LP air) I have the selinoid mounted under the tank on the top of the inner fender
Bossman69
posted June 11, 2003 12:41 PM
That is where i moved mine to now. I have not tested it at WOT but it shifts better on the rear wheel stands already Now if I can get it to shift with a 60 shoot
0.20937490463257 seconds processing time
