12rounds
posted May 07, 2003 06:54 AM
chain guard
where can i get a chain guard for a 6 over arm?
RAC4IT
Bergie
posted May 07, 2003 09:10 AM
www.goldstar.com
RedBull
posted May 08, 2003 04:15 PM
Make it yourself...
ABS plastic gets plyable after being in the oven...
Make what you want out of cardboard first,
then cut the plastic to match, & heat it up,
put on some gloves & bend it over a board.
It sounds really simple because it is !
We make all of our ABS parts at www.NationalRV.com
It's amazing what you can do with plastics, & it's light.
Red, *<(:{)-
1998 Prostar West Super Gas top ten.
1999 Prostar West Super Gas Champion !
2000 NMRA / Prostar Pro E/T runner up.
2001, 2002, & 2003 NMRA Pro E/T Champion !
2004 #3, 2005, & 2006 NMRA Pro E/T runner up.
2007 Pro St. Legal #6, NMRA Pro E/T Champion !
2008 Motorcycle Drag Race Assoc. SS Champion !
www.dragbike.com - www.MDRA4U.com
www.PMRcomponents.com www.NAARDEN.biz
Photos by www.HooliganUnderground.com
kawachan
posted May 09, 2003 06:22 AM
Some events require metal chainguards. Plus, if the chain ever broke, I'm sure an aluminum guard would hold up better.....probably not "much" better, but every lil bit helps.
RED NINJAS RULE!!
your car is slow
Fuck Nitrous...Got Boost?
posted May 09, 2003 07:41 AM
eh...I seriously doubt light aluminum would do anything more than add shrapnel to the list of objects that come in contact with your bike...and your leg if you lost a chain at WFO over 100mph.
Now perhaps a stainless steel one
Im going to see if I can make somthing up in the welding class im takin.
Do not taunt happy fun ball!
wannabe
posted May 09, 2003 03:10 PM
The only plastics ones that are allowed per NHRA rules are the ones that come stock on the bike. Otherwise, they spec out minimum thicknesses for steel or aluminum. But, I've seen what a busten chain can do to the tail section of your bike. This is somewhere I wouldn't skimp.
"There are only three sports: bullfighting, motor racing, and mountaineering; the rest are just games." - Ernest Hemingway
RedBull
posted May 10, 2003 06:29 AM
They are building driveshafts out of plastic now !
I saw one at a hot rod show in TN.
They used to think aluminum was weak, (for a drive shaft)
Composite abs plastic can hold up better than you might think.
posted May 12, 2003 08:16 AM
I took my CF Hugger and cut the curve off and pop riveted the Stock one on the end! Now I plan to put a piece of 1 x 1/8" under the plastic and pop rivet it to the assembly! Fits all of the rules and as safe as it can get!
jus1975
posted May 27, 2003 08:54 AM
I will have stainless chainguards very shortly for sell. And they will be in stock length and extended lengths.
Lorcan
posted May 27, 2003 12:27 PM
In my club (and in some British road racing clubs too) we now have to run a chainguard below the swingarm, as well as above.
Thank the insurance companies for that one....
810cc - 211mph: www.750turbo.com
zx12girl
Adrenaline Junkie
posted May 28, 2003 08:20 PM
quote: I will have stainless chainguards very shortly for sell. And they will be in stock length and extended lengths.
Hey! When do you think that you will have them?
1bad12r
posted May 29, 2003 09:48 PM
Who will have one for a Trac alum arm ? 4" over ?
768 Ryderz
posted May 30, 2003 01:06 AM
quote: Who will have one for a Trac alum arm ? 4" over ?
any reason you aren't getting the Trac ext chain guard???
1bad12r
posted May 30, 2003 05:17 AM
Got the arm from a friend used. I don't see anywhere to mount a chain guard, really don't think I can put one on it.
768 Ryderz
posted May 30, 2003 07:25 AM
no problemo w/the Trac chain guard, you just have to drill & tap a couple of holes. Takes about 10 min. I did my 10" Trac arm & extended guard a couple o' weeks ago, and if I can do it ANYONE can do it! Call em up, they have the guards in stock.
ZX12R NINJA
posted July 25, 2003 05:30 PM
http://www.tracdynamics.com/e-catalog/catalog_swingarms_alumitrac.htm
