BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Best top speed / land speed tire??? NEW TOPIC NEW POLL POST REPLY
jrob
posted June 16, 2012 05:40 PM
i would like to know what is the best tire to have for top speed?
power one, power cup, full slick anything else?
i know full slick is pretty sticky when hot but what do you think is best?
thanks!
10.02 @ 138 stock wheelbase no
strap no drop kit
9.19 @ 153 best to date
shiphteey
posted June 16, 2012 07:14 PM
I've had good luck with Pirelli Supercorsas.
I've had good luck with older gen Dunlop 208.
I've had good luck with Michelin Power One/2CT/Pure
I've had good luck with Dunlop slicks and even the one of the cheapest name brand Z rated tires on the market...Conti motions.
In essence, if the tire doesn't explode and ends up giving you the grip you're looking for given your application then its good.
A.
Gemini Motorcycles
jrob
posted June 17, 2012 04:49 AM        Edited By: jrob on 17 Jun 2012 12:50
that why i ask...with a pilot power and my weight, over 178-180mph i spin real bad and i can't go over that speed...
i don't know witch one have the softest compound / best grip??
strap no drop kit
posted June 17, 2012 05:22 AM        Edited By: Shane661 on 17 Jun 2012 13:23
How is it that you are spinning the tire at 180 mph? What is your application? High-boost Turbo? Huge shot of nitrous?
Are you logging wheel speed? What is your indication of wheelspin?
jrob
posted June 17, 2012 05:47 AM
same day...2 run one after the other 1000rpm more and 1mph less and buddy fallow me and saw the black mark on pavement...i don't believe him and i follow him and same thing....
strap no drop kit
posted June 17, 2012 06:34 AM        Edited By: Shane661 on 17 Jun 2012 14:36
Well, don't take this the wrong way...but unless you are making huge hp, or you bounced over a big bump, there is no way you are spinning the tire to the tune of 1000 rpm, at 180 mph. I would be looking at my clutch.
Even a good sport-touring tire is adequate for most LSR apps. Even on 200+ mph bikes, with heavy and light riders. Just out of curiosity, how much do you weigh?
Ken 12r
posted June 17, 2012 01:27 PM
200/55 Power one or Power cup is the best I have used recently try it with 40lb of air pressure first if you need to get more grip you could drop to about 35lb cold.
Some surfaces have poor grip levels so you have to just live with it.
www.uklandspeedracingassociation.co.uk
shiphteey
posted June 17, 2012 03:01 PM        Edited By: shiphteey on 17 Jun 2012 23:03
We do that all day on R1s....no Darkies.
Depending on the year we have found they have a soft limiter at that speed in 6th which is hard to hear/feel onboard but listening to the flyby you can hear it....barely....its not the "NUN-NUN-NUN-NUN-NUN" sound you hear when on the limiter of many bikes its more like "Nnnnnnnnnnnnnnnnnnnnnnnnnn didnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn didnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn"
Get your suspension dialed in for your weight to ensure that is not the reason for your presumed traction problems.
A.
Gemini Motorcycles
jrob
posted June 17, 2012 04:53 PM
i have no speed limiter on my bike and yess i have wheel spin at over 175 mph...
strap no drop kit
jrob
posted June 17, 2012 04:58 PM
i made maybe 8 pass with no limiter in it and my friend with exact same bike with the soft limiter passed me even if a was 800 rom more than him...i have black mark chasing me and only do 181 mph...he took my bike and made a 186 mph pass and push my bike one the redline...i weight 150 and he weight 225...
strap no drop kit
posted June 17, 2012 05:15 PM        Edited By: Shane661 on 18 Jun 2012 01:23
Wow. Your setup and/or technque is jacked up in some way. My GF just went 201.76 in the mile on my 14R, on a Sportec M3, and she is lighter than you. And I never touched the shock from the factory!
1000 rpm wheelspin...come on, man. Set your suspension up...your bike has to have the rear tire in the air if you are seeing that much wheelspin....unless your clutch is slipping.
Get a datalogger and then report back. This is not a tire issue.
jrob
posted June 17, 2012 05:31 PM
maybe not 1000 rpm of wheel spin but 500-800 rpm more and et pass by an other that was factory stock with speed limiter...
strap no drop kit
jrob
posted June 17, 2012 05:34 PM
i know those r1 are not aerodynamic but...i'm 200% sure that was not a clutch issue and i have black mark behind me is a good sign of wheel spin...
strap no drop kit
Ok man, good luck in your LSR adventure. I've given my best advice.
jrob
posted June 17, 2012 05:39 PM
i'm not really in the LSR game but i just want to get the best out of my little bike, i will try some other tire maybe the power one and if it is the same think i'm probably wrong
strap no drop kit
Ken 12r
posted June 18, 2012 07:26 AM
Is your bike stock length ??
posted June 18, 2012 09:07 AM
I'm with Shane.
It is exeedingly unlikely you are spinning the rear tire, laying down black marks at that speed unless you have 120psi, an oiled down tire, or an oiled down track.
I've run a 10" arm with 235hp, 40psi Pirelli SC2 and got maybe a few % slip at 200mph
With my Busa i get the same %slip wiyth 280hp, 3.5" arm, 28psi Power One.
Look elswhere for the cause of rpm increase. As mentioned above the soft limiter makes a good candidate.
Then again, i always agree with Shane!!!!!!!!!!!!!!!!!!!!!!!! ;-)
jrob
posted June 18, 2012 03:24 PM        Edited By: jrob on 18 Jun 2012 23:26
i'm not disagreed with Shane but i know from my eye that black mark behind me and my friend...next time i will bring my new go pro with me...
i know r1 are not good for top speed also no i'm not extended for top sped run...i don't know if running extended will help for top speed?
thanks
strap no drop kit
shiphteey
posted June 19, 2012 04:33 PM
Is this a smooth flat road?
Gemini Motorcycles
jrob
posted June 20, 2012 02:28 AM        Edited By: jrob on 20 Jun 2012 10:29
yes it is...http://www.youtube.com/watch?v=VaTnrJGFcPA
this is my friend with is old busa...making 198 on the big stretch...
i have not upload my video yet but i have some video from the side of the road and its really nice flat spot where we make top speed run...i think is the last stretch of the video
strap no drop kit
shiphteey
posted June 20, 2012 11:56 AM
Still voting for suspension....
Any chance your tuck is so horrible that you are getting lift in the back? ?!!!??!
Hah I dunno man, start with suspension and rerun the bike.
A.
Gemini Motorcycles
jrob
posted June 20, 2012 05:00 PM
thanks for the advice...can you tell me what kind of suspension set up i need to have?...right now i have set my suspension close as possible four drag racing...
strap no drop kit
jrob
posted June 21, 2012 04:14 PM
do you know how i can set my suspension for top speed run? also for theses who run some r1...do you know how mph each year make?
my friend bought an 04, 06, 07 and 09 r1. the 04 and 06 made 185-186 gps ,stock on the soft limiter, 07 made 184 and the 09 182 (soft limiter) and 184 without soft limiter but i would like to know what other people get with those r1?
Thanks!
strap no drop kit
shiphteey
posted June 21, 2012 04:54 PM
I've run 3 different 04-06 models and with a so-so setup 179.9 to 181.1 mph. WIth proper tuning and bolt-ons we've gone 186 on GPS out there but it had an 08 motor shoehorned in. From everything we've seen (on the dyno, havne't topped out the 09+ models) the 09+ make...."lackluster" hp out the box....a smidge less than the 07-08 4v head IMO.
Have you had anyone else jockey your bike to see if this can be duplicated?
Basically with the R1 you start a solid step behind SUZ/KAW/BMW in terms of potential. Are you serious about land speed or just want to get everything you can out of your bike? Because you are fighting an uphill battle with the R1.
A.
Gemini Motorcycles
jrob
posted June 22, 2012 02:11 AM
no i'm just trying to get everything i can out of my bike...if is not that i put already some cash in my bike and the new bmw is little pricey...i would go with a new bmw...
thanks
strap no drop kit
0.22790789604187 seconds processing time
