BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: strange damage? NEW TOPIC NEW POLL POST REPLY
posted November 12, 2011 03:41 PM
strange damage?
So a local guy brought me his bike to work on. needs to get it fixed and wants to do upgrades at the same time. he ran it low on oil, and was doing about 200kmph (closed course im sure:P) and he said it felt way down on power all of a sudden, and then locked up. Im thinking rod bearings gotta be toast as hes telling me this.
i drained about 1 quart of "gold fleck" oil out of it before pulling the pan (all that would come out) as i wanted to stick a flat pan on it to make life easier wrestling it out by myself.
#4 is gone. but to my suprise the piston is also destroyed. how the rod didnt windmill the cases is really beyond me. im thinking it spun the bearing, then must have hit the head so hard it shattered the piston, or it broke a valve off too.
his bike is totally stock except for a slip on and air filters
anyway i thought it might be interesting to you guys, ill have more pics later as i strip it completely
zx12mark
posted November 12, 2011 04:21 PM
scott ,you got your hands full.he`s better off buying a used engine don`t ya think.i would
posted November 12, 2011 04:32 PM
well if you want a bigger crank and bigger pistons anyway....
posted November 12, 2011 10:25 PM
got a little further into it. the rod literally moves up and down 0.75+-0.1 of an inch. i like a little closer to 0.0025 personally... he said it locked up, and i cant manually turn the crank over, it will go forward and back, but not past a certain point. im thinking something causing interference with the crank and clutch gears, theres a lot of shrapnel.... i will split cases tmrw
IN cam. head and cap didnt like getting run dry
i would say she was being ridden hard and getting the carbon burned off... it flakes off if you touch it
job for millennium
SteddyTeddy
posted November 13, 2011 05:36 AM
Looks like its time for a new motor!!
posted November 13, 2011 06:54 AM
cases might be ok, not really sure till they come apart. they got rubbed by the bad rod. 3 rods are fine. hopefully nothing got in the trans. i think the block would be ok for a big bore. weld up the bottom and get it bored and plated. the head is looking like it may be toast. even if the cam is cleaned up, and the surface of the head/cap touched up, it may be a location for oil pressure to be bled off? really wish the cams had replaceable bearings too....
posted November 13, 2011 12:28 PM
im having a hard time believing that the pin bore is in such good shape. the pin pushed right out
750 turbo
posted November 13, 2011 02:35 PM
Scott by the looks of all that damage,time to start searching for complete engine.By the way what is new with you?
posted November 13, 2011 03:18 PM
needs a head, crank could be fixed or stroked, but i think hes looking at just getting a good used stock crank now. i have an extra rod he could use. a little epoxy on the bottom of the cases, and its allready half clearanced for a stroker crank at a later date... im pretty sure millennuim can fix the block and make it a 1287 for about the same price as just repair. going to send them pics and get a quote.
did you see my turbo build?
750 turbo
posted November 13, 2011 04:23 PM
Yes i was loking at it.
posted November 13, 2011 08:30 PM
Wow,
That guy didn't quite know when to get out of the throttle.
NINJA12
posted November 14, 2011 12:57 PM
He's lucky it locked up.LOL
That could have been a nasty accident.
Crank maybe, but I would find a block.
Zx12 stuff pretty cheap now.
posted November 14, 2011 06:59 PM
millennium said they can fix it. i sent them those pics. i have 3 spare 1287 pistons hes getting from me. going to put together a combo very very similar to the motor in dads bike.
2000redrocket
posted November 14, 2011 07:07 PM
one word > wow. check your oil i guess
posted December 28, 2011 05:59 PM
this is head #2 he got for me to work on, not the best pics, some i got with my phone...
the IN cam thats pictured above cleaned up nicely. it was mostly aluminum stuck to it that polished off. very very minimal scratches, nothing to worry about. cams are off to get adjustable sprockets pressed on, and the head is away to get surfaced
heres the block repair
surfaced locally
a shot of the ex valves in the old head
the valve seals were quite worn, the valves actually felt rather loose compared to what Im used to(pulling up and down, guides felt normal). lots of build up on the valves (ex)
epoxy repair. I left it thick on the outside. quick blast of primer and high temp black paint. (I know Im no painter)
posted December 29, 2011 12:21 PM
top rings were all about .009 out of the box, and the second rings were all about .017-.018
set the tops to .015, left the others alone
hyperdriver
wheelies to the parking lot
posted December 31, 2011 12:29 PM
ya, he blew it up alright!
like bikes
busaeater01
posted February 15, 2012 06:12 PM
looking good
Hey Scott,
I've been meaning to ask you, what was the root cause of the last pre turbo engine failure you had, where you threw the rod through the case? What was your set up when that happened?
Thanks,
Luke
Death is Certain, Life is Not
posted February 15, 2012 08:08 PM
this thread is not about my bike its a friends(and the last pieces should be in this week finally). bone stock, no oil, high rpm
if you want to talk about my 1380 pm me
busaeater01
posted February 15, 2012 10:07 PM
sorry, but can't pm on this forum, tried pm'ing you on kawasakiworld, but you never responded.
posted February 15, 2012 10:35 PM
if you turned it off, turn it back on, i can pm other people here. i didnt get anything on the other forum?
busaeater01
posted February 16, 2012 02:21 PM
that's weird, i'll see if i can figure it out
posted April 04, 2012 06:43 AM
finally got the last of the parts and its going smoothly
set timing to 106 106, should be a fun street n strip motor. lots of PTV clearance. CR at 12.7:1
robby425
posted April 04, 2012 12:24 PM
kzscott i tried to pm you, do u have a number or email??
posted April 04, 2012 01:26 PM
s_u_fire@hotmail.com
0.23389720916748 seconds processing time
