BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: duster is down for the season with cracked block NEW TOPIC NEW POLL POST REPLY
2000redrocket
posted October 13, 2011 01:52 PM
at cecil i had my first track oildown by me.
at numidia i was told i was leaking oil so i changed the valvecover gasket. guess i was wrong. saturday at cecil first pass was a 10.27@131.74 with a 1.55 stumble.
next pass i came out at 3000 to get past the small pump cam i put on to try and got a 1.48 60ft. well i oiled the track that pass just after the 1/8 mile.
i cracked the block at a freeze out plug. i wish i would of filled the block with block filler halfway on this one like the last one.
i am glad i did not pull the engine to fix the real leak of the oilpan. cause when the blocks water jacket went through and filled the pan it came out there big time and let me know.
i may be able to reuse the rotating assembly with no issues.
now for a race block or engine filler in my spare block.
sucky end. now to play with the bike now.
posted October 13, 2011 02:42 PM
i feel your pain
posted October 13, 2011 02:55 PM
I have a mega block and B1 heads i'll sell you ..
2000redrocket
posted October 13, 2011 06:21 PM
jeeze. my story is i am happy with low 10s. there is a door ar 10.00 that is closed and expencive to open. i actually do not need more power for what i have. but the dam block thing is go stock again and risk it or a expencive raceblock and prep on a engine i have 5500 into it and now a season later it needs a block for my internals.
please tell me what you need for the block though cause i still need one and what bore though i am guessing that is not a big deal.
and the heads though i will say i have indy cnc 440-1s that go 375cfm already i am not using. (got from jake zaring for pulling truck)
thanks
Y2KZX12R
CompetitionCNC.com
posted October 14, 2011 03:45 AM
RR, I'll see if we have any blocks hanging around here in the shop.
Y2KZX12R
CompetitionCNC.com
2000redrocket
posted October 14, 2011 07:44 AM
thanks jim.
i have one but the pistons are stuck.
till i get them out i am not sure what it will look like in the bores.
someway i will end up with a block and if stock it is getting the waterjackets filled
halfway this time.
2000redrocket
posted October 15, 2011 07:01 PM
here are some pictures of the damage.
i got lucky it did not come apart and kill everything
Bigbore4
posted October 20, 2011 02:34 PM        Edited By: Bigbore4 on 20 Oct 2011 22:36
That's a big crack!
Paul2281
posted October 20, 2011 02:57 PM
Holy shit brother......
What was the chain of events you think that caused this to happen,any educated guess`s????
Thank God you caught it....
2000redrocket
posted October 20, 2011 08:47 PM
no one can tell you the life story of a engine block. Y2K can back that up i bet. so maybe core shift when it was cast. who knows.
the responce is it should of not broke like that. well duh i am thinking that also but it is the truth. some are running 10.0s on a stock block others like me brake one running slower.
i have dibs on a block from the late 70s that is a heaver casting. i am also putting a stud girttle on it and filling the water jacket halfway with block filler to stiffen the block up.
440source.com is a great place to deal with.
0.22564506530762 seconds processing time
