BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: auto nitrous map switch DJIIIusb w/hub NEW TOPIC NEW POLL POST REPLY
almost_les
posted July 06, 2011 07:54 PM        Edited By: almost_les on 7 Jul 2011 04:39
boom shacka lacka
almost_les
posted July 06, 2011 08:04 PM        Edited By: almost_les on 7 Jul 2011 04:20
goes to the nitrous map as the failsafe, when on motor it connects the #2 and #3 hub pins to a chassis ground to run the leaner motor map. wont allow the nitrous relay to activate unless the map is also switched since they are on the same relay.
double check everything by doing a run without spraying to make sure everything is connected properly and its adding the extra fuel when activation is pressed.
JOHNJ
posted July 07, 2011 04:21 AM
Nice,very nice.
ZRXDean
posted July 07, 2011 06:03 AM
Very cool Les, thanks for posting.
02zx12rbob
posted July 07, 2011 12:14 PM
+1
almost_les
posted July 09, 2011 06:22 PM        Edited By: almost_les on 10 Jul 2011 02:26
made some revisions. turns out you can do it with a spdt relay instead of a dpdt relay
0.27120685577393 seconds processing time
