Y2KZX12R
CompetitionCNC.com
posted April 06, 2011 04:44 AM
06-07 and 08-09 engine differences
I got a call the other day when a customer had an issue putting in his new stroker crank in his cases. So I thought I'd point out a few of the differences in the 06-07 and 08-10 engines.
The 08-10 cases don't have selectable crank end play bearings. So you don't need them from the 06-07. The cases have the end play pads cast in.
The 06-07 crank has 61 teeth on the crank gear driving the clutch basket and the 08-10 has 58 teeth. So you need to use the basket from the appropriate year. The 06-07 has an anti backlash spring loaded gear on the clutch basket and the 08-10 does not.
The starter gear shaft is retained by a sheet metal bracket on the 08-10 and you cannot screw in the shaft retainer nut from the 06-07 cases.
There are a few more little differences but nothing really tricky.
Y2KZX12R
CompetitionCNC.com
trganey
posted April 06, 2011 06:39 AM
Thanks once again for your enlightenment!
TR
ZRXDean
posted April 06, 2011 08:01 AM
Thanks Jim. For historical and search purposes, this is for the ZX14 engine I'm guessing.
Y2KZX12R
CompetitionCNC.com
posted April 08, 2011 07:45 AM
yea sorry..... for got to mention that...... its for the zx14.
Y2KZX12R
CompetitionCNC.com
pancho14
posted April 10, 2011 08:52 AM
Im new here has anyone experienced with 1452ccs zx14 i use the Cp Pistons with the Muzzys cams! How many nitrous he holds?
I will use this Bike only for the dragstrip!
Thanks Guys
WRECKSHOP
posted April 11, 2011 09:07 AM
Hey Jim, have you received a 2011 ZX-10R cylinder head yet ?
Y2KZX12R
CompetitionCNC.com
posted April 12, 2011 04:01 AM
Been out of the shop sense Tues. I'll be back today.
Y2KZX12R
CompetitionCNC.com
