BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 08 busa quick shifter NEW TOPIC NEW POLL POST REPLY
posted March 18, 2011 05:32 PM
having trouble with the software. this guy has the hub, and pressure sensor (instead of the button). the hub is working as it will activate his shift light.
when i pop in the cd and open the pc3 usb shift kill utility, it wont connect to the pc so it wont let me enable shift kill. it comes up error connect failed 0, and when i try to click on enable shift kill, a pop up window comes up showing no power commander connected. i can close this program however and open the pc control center and connect to the pc just fine
this is with the pc on the bike. does it need to be done with the 9v programmer? something else i noticed is the pc is only powered when the fuel pump relay is activated. so the bike must be running to connect to the pc and see what map its using. i have it setup with dual maps right now as one will be his dry nitrous map. with the key on, the pc only connects when the pump primes. or you can jumper the relay and get the fp to run steady as if the bike were running and play with maps then. this is different from my 12 as it only needed the key on to power the pc.....
0.46146202087402 seconds processing time
