BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 150? NEW TOPIC NEW POLL POST REPLY
posted March 16, 2011 06:39 PM
150?
how much would you spray on a stock displacement 12 with a set of 13:1 forged pistons, SS valves, build trans.....? I remember hearing that Coby used to put a 120 shot on a 1287.... stock bore should handle a fair bit more?
ZRXDean
posted March 16, 2011 07:04 PM
With good fuel, retarded timing, and a fat AFR, I'd say go for it. Only one way to find out what it will take
TRNorBRN6001
posted March 17, 2011 06:37 AM
1/4mi, maybe start with a 100 shot and enjoy it for a while.................................getting too conservative in my old age! LOL.
TFA 200MPH CLUB MEMBER!
chavcat
posted March 17, 2011 10:29 AM
Scott - Jim O told me he used a 100 (or 150 I would have to check this) on his salt bike using Carrillos and stock bore JE's. I would think 150 in the 1/4 would be OK.
gilberjj
Friend of Fast
posted March 17, 2011 12:32 PM
JOHNJ
posted March 17, 2011 12:51 PM
Like Dean says, It`s having good fuel octane,a timing retard map,and DO have the rpm`s. up before initializing the N2o. I`ve seen others push the button,switch,ect. with the rpms too low and "pop" the head gasket or blow the carb`s off . JMO.
posted March 17, 2011 02:29 PM
it would all be on a progressive hit on a window switch. no push buttons. i have an efir-12, and the wet kit has its own fuel system(tank, reg. pump) which would be on C-16.
shiphteey
posted March 17, 2011 04:31 PM
Strip only? And C16....maybe 100 for starters....cheaper to up jet sizes than rebuild motors.
Gemini Motorcycles
posted March 17, 2011 06:57 PM
well i was thinking 100 lsr 150 drag... setting up egt...
Johnnycheese
posted March 17, 2011 07:04 PM
done 1270 with 175 and 13.5:1 no problem
posted March 18, 2011 12:01 PM
how much timing was pulled?
Johnnycheese
posted March 18, 2011 01:48 PM
4
posted March 19, 2011 01:21 PM
on straight C16? Q16?
Johnnycheese
posted March 19, 2011 07:11 PM
C12
2000redrocket
posted March 20, 2011 06:17 PM
scott you better have good velcro holding you to the bike. at least you are going progressive. imagine a 100 or 150 wet all in. wohoo.
posted March 20, 2011 06:49 PM
something tells me it might flip over..... you remember the vid of dads nitrous wheelie? that was only 50 hp lol
2000redrocket
posted March 20, 2011 07:03 PM
back in the day they let me run 10lb of weights on the front of my zx11c. maybe you should go for at least 20lb lolol
posted March 22, 2011 04:18 PM
i have 2 oem batteries where the lights used to be
it still wheelied at 72 in wb with my 1380 NA
2000redrocket
posted March 22, 2011 06:13 PM
well i am slowly collecting parts which may get to a 1375cc stroker. i hope i do not need two batteries to start the dam thing.
0.29377007484436 seconds processing time
