BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Nikasil honing NEW TOPIC NEW POLL POST REPLY
Mikkel
posted February 22, 2011 01:25 PM
Nikasil honing
I have a 85,4 mm 1270 cylinder/piston kit for my zx12 with one damaged piston. I wonder if the cylinder can be honed to fit a set of Wiseco 85,5 pistons? According to this the nikasil coating is 0,6 to 0,7 mm thick: http://www.enginebuildermag.com/Article/2300/the_smooth_science_of_cylinder_honing.aspx
Or perhaps someone has a good 85,4 mm piston they want to sell:-)
ZRXDean
posted February 22, 2011 01:49 PM
I think you'd be better off with a new piston of the original bore. Who manufactured the piston? I have purchased single Wiseco pistons, and I know JE will sell singles. Better yet, but a set, and you'll have spares for next time
Mikkel
posted February 23, 2011 01:50 AM
85,4 is a special size made by JE for Muzzy. I guess the best thing to do is to buy me a new set of pistons from Muzzy but it is just so expensive with shipping to Denmark and import tax and I can get a set of Wiseco 85,5 mm pistons here in Europe for much less.
ZRXDean
posted February 23, 2011 08:43 AM
Sorry, I forgot about the unusual bore size of the Muzzy piston, I guess JE won't sell one directly to you?
Can a single 85.5 be machined to 85.4?
Mikkel
posted February 23, 2011 10:52 AM
I can only buy the 85,4 piston from Muzzy. I don“t think machining a 85,5 piston to 85,4 is a good idea. I will ask the local machine shop about machining the cylinder to fit the 85,5 pistons.
almost_les
posted February 23, 2011 01:34 PM        Edited By: almost_les on 23 Feb 2011 21:34
talk to millenium. they are the pros on boring/coating/honing
http://www.mt-llc.com/
posted February 23, 2011 05:42 PM
Did you check and see if you can buy one replacement piston from Muzzy? They used to carry single replacements.
The reason the 85.4 piston size was chosen was because of the thinner, lighter rings available in that bore size.
Mikkel
posted February 24, 2011 10:15 AM
I can get a single piston from Muzzy but with shipping and import tax it adds up to about 450$ so that is why I was thinking of buying a new set of Wiseco pistons for just a little more money. I will ask Millenium if honing the cylinders 0,1 mm bigger without replating is possible.
0.20516705513 seconds processing time
