BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: What would you do? NEW TOPIC NEW POLL POST REPLY
brendasue555
posted January 02, 2011 01:35 PM
What would you do?
I am thinking about running the 2000 zx12r at the March Texas Mile. It is 100% bone stock. What , if anything should I do to it before I run it? It would be very interesting to see how fast it will go just like it is. Does anyone have a metal chain guard or mirror block off thingies that I could borrow for this one event? Anyway I would love to know what you guys think I should do to the bike befor I run it. Thanks........
Bren
Brenda
posted January 02, 2011 02:51 PM        Edited By: entropy on 2 Jan 2011 22:53
IMO do absolutely nothing other than required steering damper, safety wire, metal chainguard.
bring an extra rear spkt that'll get you to 200mph in case we get a tail wind (once so far in 7 years)
you could dump a shit load of $$ into pipe, PC3R, race fuel, tuning, and get what, 3-4 mph more?
Not worth it, I say run stock, including mirrors if they'll allow it
just my opinion...
Johnnycheese
posted January 02, 2011 03:38 PM
if you needed a pipe I have one and I think a pc3r I could donate to the cause BUT>>>>>>>>>>>>>
I am with Karl on this run what you have
gs11ezrydr
posted January 02, 2011 04:16 PM        Edited By: gs11ezrydr on 3 Jan 2011 00:41
Besides all the other really good suggestions you might also consider a fresh motor oil and filter change, air filter,spark plugs,throttle body sync,TPS adj.In other words a good tune up,Inspect all fluids,top off or change if nesc.Brake pads,rotors, hoses etc Do a safety inspection,all bolts, fasteners,etc.as noted earlier saftey wire where required.Chassis stiffen or lower as needed.Drive chain inspected or replaced and properly lubed and adjusted.Do all the things that insure a efficient running engine,and safe handling machine.Have fun and good luck.
  Ignore this member    Click here to visit gs11ezrydr's homepage.
tshultz
posted January 02, 2011 06:19 PM        Edited By: tshultz on 3 Jan 2011 03:40
Ive got some sprockets. chain guard you can barrow if you want.??
i have some mirror block off bolts so on. pm me with what ya need.
TRNorBRN6001
posted January 03, 2011 10:00 AM
Run it stock, should be good for low 180's with Texas Mile winds. I do believe I have mirrow block off plates and a chain guard I could lend you for the Mile. I'll have to check the chain guard though as it might be too long.
TFA 200MPH CLUB MEMBER!
posted January 03, 2011 11:36 AM
I think Brenda could easily be in the 190's unless we get winds like last Oct...
go-Brenda, GO!!!
brendasue555
posted January 03, 2011 01:06 PM
Now I am getting excited. Of course the bike will be gone over, it stays in excellent condition Including good tires, fresh brakes, new Motul 300V oil and filter, Thanks to all for your kind offers I will let you know what I end up doing but I am leaning heavily toward bone stock with no mirrors.
Brenda
Y2KZX12R
CompetitionCNC.com
posted January 03, 2011 01:16 PM
I vote for 100% stock no mirrors. And bring some rear sprockets!!!
Doug may be going this year so he can work with you on extracting the most out of her.
Or is it a him?
Y2KZX12R
CompetitionCNC.com
BrooklynNYZX12
posted January 03, 2011 05:11 PM
I agree,some sprockets all the rule abiding hardware and put some #'s down,I own a 12 and a 14 but the 2000 ZX12R has a mystique about it.
Orient Express Top Street Bike Winner 8-4-07
texanzone
posted January 03, 2011 06:00 PM        Edited By: texanzone on 4 Jan 2011 02:01
The first time I ran the Busa there was my first time to run it anywhere.It was stock but for a pc3,a JC tune and a little lowering.Thats how I ran in on the street,mirrors and all.Just wanted to see what it would do.Got a 179.something,then the bug bit.
shiphteey
posted January 03, 2011 09:17 PM
My recommendation is to keep it near stock and ride the bike, get some passes under your belt. See what the bike likes....see where you feel it benefits you to shift. Get comfortable on the bike. You can always mod it but the less power you go out there with the more I feel you can learn and improve. Thats what its all about. If it was just about guaranteeing a 200 mph pass you could jump on an overpowered turbo busa and it would be a walk in the park...but really what woud you learn?
Pass tech, bring sprockets, learn how to swap em back and forth safely with someone experienced helping you out your first couple of times.
If you get anywhere near 200 mph on the stocker with the seat time you'll know you can go back, throw on the pipe, pc3, filter, tune it, do some other budget minded mods here and there....starts line up and it'll be 200+.
Best of luck.
A.
Gemini Motorcycles
TRNorBRN6001
posted January 04, 2011 08:50 AM
I think my first run down the Mile on a 12 with pc and pipe was 177ish.
I wouldn't worry to much about sprockets (one tooth on either side), Just be sure to stick around Sunday and Hot Lap that old 12, lol. I may have some clutch springs laying around you can slip in for just running the mile, if you like. Plus you can check your clutch and make sure it looks and measures well. I'd hate for you to go to the Mile and have the motor go through the clutch on the big end.
2000redrocket
posted January 04, 2011 03:14 PM
i would add some stiffer clutch springs also. and a dampener.
brenda you could tare out the cat stuff in the stock pipe.
brendasue555
posted January 04, 2011 03:26 PM
Gary those clutch springs sound like a good idea, and Ali, I have a bit of seat time on the 12 I know it will do 170's no problem. I know the mile is different but I can't wait to try it on the 12 while my 11 is down. What does tare out the cat stuff mean?
Brenda
2000redrocket
posted January 04, 2011 03:31 PM
when you unbolt the muffler and remove it the cattlist stuff will be in the end of the head pipe easy to reach.
ask the collective if it is a good idea. unless you have emitions for bikes where you live it does not need to be there.
TRNorBRN6001
posted January 04, 2011 05:29 PM
I think I found my old schnitz clutch springs ( I run Brock's ZX-6 ones on my 12). I'll have to check them over at JC's and make sure they are the right poundage. If not you can just shim up the stock ones, just don't bottom them out. The down side Brenda is it will make the clutch harder for you to pull in.
posted January 04, 2011 05:35 PM
the easy way, cut most of it off, then chip out the rest
fire it up before the can goes back on to make sure all the pieces get blown out
shiphteey
posted January 04, 2011 06:00 PM        Edited By: shiphteey on 5 Jan 2011 02:02
170? Sheeeeit you're a fairly small rider, get tucked in you'll do 180+. I rode one a year ago, truely bone stock down to the mirrors, signals, cat in the pipe....even a full tank of premium fuel. At a whopping full weight I still went 181 on it in less than a mile.
As long as you don't have a big headwind you'll break 180. POSITIVE! And on that run 5th gear was a bear and 6th gear was a snoozefest so throw on a 17 tooth up front or a 47 tooth in the back to give it some more acceleration. As it sits your bike is geared much higher than it will be able to pull (Unless you have a HUGE LORING 2009 TAILWIND!)
Good luck. If you don't have a damper get that first. I had to back out of this run due to a tankslapper at the end, hard to see in the video but its there. I was slowly clawing the Yamaha back. Not enough to have passed him at the end EVEN IF the damper WAS on there but a damper is a wise investment.
A.
Gemini Motorcycles
posted January 05, 2011 01:30 AM
i don't know what this talk is about maybe 180?????
i'm with Ali, put a 47t on it
and i betcha she'll hit hi 180's in dead air. (hahahahahahaha dead air at texas)
Brenda Sue is VERY aggressive on the throttle and has a tuck to die for right off the line.
shiphteey
posted January 05, 2011 06:43 AM
Haha, thats what I'm saying Karl, she'll go faster....she ain't foolin NOBODY sandbagging like that!
A.
Gemini Motorcycles
posted January 05, 2011 08:35 AM
A.
Ali,
when am i going to see your ever-smilin' face again??????
Loring?
Karl
shiphteey
posted January 05, 2011 08:38 AM
Loring is definately a possiblity for me. Right now I'm throwing about 75% of my net income directly at credit cards so its tentative. 1-2 Maxton events and a Loring event would be great.
A.
Gemini Motorcycles
posted January 05, 2011 09:11 AM
I'd love to do a Maxton event this year, i really like that quirky place, but i'm not at all sure of my schedule.
If you go to Loring you gotta go to Jim's monday lobster fest.
Also, i been hearing that Rickey Gadson M-A-Y show up again.
tshultz
posted January 05, 2011 05:37 PM
email sent
0.22785186767578 seconds processing time
