dickhead
posted November 25, 2010 10:35 AM
165 HP on a Factory Pro dyno
My 07 ZX -14 using a Brocks map , 3 degrees retard with SB6 ,flys out mr-12 ,16-43 gear power one tire , made peak power of 165 and 97 ft lbs torque, we didn't tune we left the map as is just to see what it made, my best pass is a 8.80@150mph Looks like u don't need 200 HP to run in the 8's
shiphteey
posted November 25, 2010 02:24 PM
Wheelbase?
Gemini Motorcycles
dickhead
posted November 25, 2010 02:46 PM
65" whn I ran that time. Now it's at 68"
posted November 25, 2010 04:39 PM
Definitely don't need 200 hp to run in the 8's. What do you weigh? What track?
ZRXDean
posted November 25, 2010 06:42 PM
Factory pro HP is generally 15-20% less than Dynojet HP.
Nice ETs, how about a pic?
posted November 25, 2010 07:40 PM
quote: My 07 ZX -14 ... made peak power of 165 and 97 ft lbs torque...
seems about right; was that pulling steps or sweeps on the dyno.
Dean is correct, the FP shows 10-20%+ less hp than Dynojet.
The more hp the motor makes the bigger the discrepancy
Bigbore4
posted November 26, 2010 02:22 AM
HP is HP. The Factory Pro shows True HP. Dynojet is and always has been inflated.
The Factory pro is a better tuning tool also. Much easier on the motor.
Bigbore4
posted November 26, 2010 02:24 AM
Saying that though, the 07 with a Brocks pipe and a good map should be well over 170 true hp
posted November 26, 2010 05:20 AM
Edited By: entropy on 26 Nov 2010 13:26
quote: Saying that though, the 07 with a Brocks pipe and a good map should be well over 170 true hp
BB,
what makes you say that???
I spend a lot of time on a FP dyno and 165 is very strong, on the high end, for gen2 Busa & Zx14.
Bigbore4
posted November 26, 2010 07:18 AM
I'm going off of what Marc says. He's dyno'd some basically stock 14's and busas with slipons at around 168 to 172 true hp. I assumed the 07 had a full brocks system, although he didn't mention it. I'm real curious to see what the 11' zx10 does.
posted November 26, 2010 07:34 AM
if Marc say it, it must be so.
maybe the FP i go to reads low wrt his.
My Busa pulled 229 on a FP last Sat, but it's had a lil motor work
gixxre750
posted November 26, 2010 07:40 AM
My bike has been dynoed on both Factory Pro and Dynojet. There was only a 3hp difference. Mine made 151hp on DJ and it will run 8.90's
Bigbore4
posted November 26, 2010 08:09 AM
What bike?
posted November 26, 2010 09:41 AM
quote: My bike has been dynoed on both Factory Pro and Dynojet. There was only a 3hp difference. Mine made 151hp on DJ and it will run 8.90's
did you do a sweep on the FP (rather than steps)
i've done test on 3 different DynoJet dynos vs the FP I commonly used on my seriously built ex-ZX12: 18%, 20%, 21% higher on dynojet.
ZRXDean
posted November 26, 2010 10:53 AM
My ZX10 made 145 steady-state horsepower on a Factory Pro EC997, and 177 sweep horsepower on a Dynojet 250i. Similar conditions.
dickhead
posted November 26, 2010 12:02 PM
quote: Definitely don't need 200 hp to run in the 8's. What do you weigh? What track?
190 suited and that was at Sacramento raceway and also running Brocks sidewinder.
dickhead
posted November 26, 2010 12:07 PM
I had a 05 Zx-10 3 mil, ported head , intake cam ,thin head gasket,Brocks streetsmart full pipe and mr9 and made 161 HP with 76ft lbs torque on the same dyno.
bbwatercool
posted November 27, 2010 10:24 AM
I have a DJ dyno and the zx14's as mentioned in this post make 165'ish on my dyno as well..what you will find with most DJ operators is that they have altered the weather station to trick the computer to read a higher hp...I'm not saying all tuners do this because I don't but numbers sale tuning jobs and engine packages and 99.9% of the paying public would not know what 10 extra hp would do to their bikes overall performance let alone 30+ additional hp...so some tuners have resorted to telling lies with their dyno's to sell it to their customer(s)...the customer then takes the inflated dyno sheet and #'s to the internet and everybody else that sees or hears about it swallows it...Look at it this way..tuner A tells you he can tune it and it will make 170 hp and tuner B says he can get 185 hp..Tuner A tunes it and get you a true 170 and Tuner B tunes it and gets 170 but the dyno sheet says 185...most guys will think that tuner A doesn't know what he's doing and they pass him up for tuner B...So tuner A has to explain tot the customer how the #'s can be manipulated and that the 1/4 mph and the over all weight od the package should also validate what the dyno says...It takes XX amount of hp to accelerate XX amount of weight XX amount of mph...that equation will never lie to you..a dyno operator can...So as a tuner/builder I have to expalin this to all my customers that come to me with these 230+ dyno sheets and I have to break their hearts when my dyno shows then 210-215 rwhp..i take their 230+ hp sheet and their package weight and give them a mph and i take my 210-215 dyno sheet and give them a mph and I ask them to tell me which one is closer to correct and my #'s are almost always within +/- 1-2 mph...
BTW, I'm tuner A!!!!!!!
Cycle Concepts
1625 Lynwood Dr
Lancaster,SC 29720
803.285.8093
Home of the Drag Pak Clutch Pak!!
posted November 27, 2010 11:58 AM
"tuner A",
good explanation.
Besides tuners who intentionally inflate numbers, i think there also DJ tuners who perhaps just don't know how their weatherstaions impact numbers and run for years with them miss calibrated.
Like you say, 1/4mi mph tells hp pretty much.
Johnnycheese
posted November 27, 2010 06:05 PM
quote: HP is HP. The Factory Pro shows True HP. Dynojet is and always has been inflated.
better??? they are the same dynos period operator and tuning skills help but they are both eddie currebt brake dynos and will both do the same thing
Bigbore4
posted November 28, 2010 02:06 AM
Excuse me? Most of the DJ are inertia dynos and that's a fact. They have an optional eddie current. Big difference in cost. So, to correct you, they are not the same.
Bigbore4
posted November 28, 2010 02:58 AM
Dynojet HP niumbers:
As far as the difference between "hp numbers", the current mess in HP numbers is due to dj's unpublished inflation rate - example: Motorcyclist / Sportrider's use of a Superflow chassis dyno and Superflow's "emulation" of the dynojet "inflation rate": - which, for a high hp bike, is wonderfully optimistic, as compared to an "average reading" dynojet dyno's hp numbers.
The reason for "True" hp - is that EVERY dyno manufacturer CAN supply those numbers - including Superflow. Actually, "natively", the Superflows display "True" hp and the dyno owner can choose to inflate to "something kinda like +/- 10% of a dynojet number (and you can see the dyno brand hp number mess starting.....)
As it goes, if you are using the same dyno, you could use any unit scale, including "cans of cat food", as your torque number scale and "cat chased by dog velocity" as your hp number scale. The HP number scale makes little difference - only the difference (at least as far as the hp change goes).
The problem is that, nobody can absolutely replicate dynojet's numbers (even them).
THAT's the reason for "True HP" - nothing more than what you learned in the first week of science class - "If your experiment can't be duplicated by others, it's invalid.".
No other dyno company can duplicate a dynojet number unless they supply exactly the same engine load and have exactly the unpublished dynojet inflation factors.
Testing Procedures:
As far as there being a difference in tuning on the Factory Pro or a dynojet style dyno, there is a difference -
The biggest difference is that most professional tuners who have Factory Pro EC997's tend to use steady state testing - as compared to the majority of dynojet guys who test HP with a 4th gear, 5 second, inertia load, "wack".
I'm here to tell ya - that there's a potentially GREAT difference in "optimal" hp results "on the dyno" vs. what works in the real world.
What makes "Best Power" in a 4th gear wack on a dynojet - is probably not what works best in the real world (as somebody posted) - the Load on the dj dyno is WAY less than the real world - and all the combustion chamber temps are at least 300f (probably 500f to 600f ) less than what happens in a Steady State test or in the real world - and that skews the tuning and the power results - and throws away hp in the real world.
A Steady State test isn't exactly "natural" for most real world stuff, either, (except when topping out the bike > that's the 180 mph real world Steady State Test), where it's 100% equal and realistic loading - but, if a Steady State test is off, at all, it's a very small amount whereas Best Power on a dynojet vs the real world can be 5 mph "off", as stated above in someone's post.
However, being the veteran user of a dyne system that will easily do steady state with one mouse click or a sweep test (ala dj) with a click of the mouse - and in that sweep test, I can specify any acceleration rate from 1 fpf/s (ridiculously slow) to 50 fps/s (ridiculously quick) - it becomes pretty obvious after a few dyno tuning vs. track testing sessions, that the Steady State tests provide the most reliable results and that anything quicker than about 25fps/s dyno acc. rates are sketchy. And a high hp bike on a dj might be 40fps/s +.
The Factory Pro dyno was designed and built to be flexible in testing methods and quick reacting - and the dj, was built to do inertia hp testing and to automatically "tune to an AFR" and isn't as flexible as the Factory Pro. (only "biased" because I know from experience)
The Factory Pro tuning methods are different than the dj systems -
The Factory Pro method is to tune the engine till it makes best power and use the 4 gas EGA to give hints along the pathway (sounds harder than it actually is) and then, when you have Best Power, use the 4 gas EGA information to give more hints as to what you might do to make it even better Llike:
Is the ignition timing "optimal?
Is the cylinder to cylinder fuel "stagger" OK?
Is the combustion chamber very efficient?
Is there reversion at some rpm?
Is there "too much" cam?
(that's all from a tuner's experience - and if that makes me biased in your opinion, well, fell free to draw that conclusion ;-)
It's tuning to Best power, Steady State, not a dj type "4th gear sweep" Best Power (which doesn't work well, as previously posted).
The dj method is to $300 tune it to the "best" AFR and, well, that's about it, unless they want to poke and prod at the pc3 numbers to see if you can make more power in a 4th gear sweep test, that probably won't be the tuning settings that work the best in the real world (as someone here posted).
The Factory Pro method is (or "might be") a bit more expensive, but, gets the same results as Jordan Racing, Vesrah Racing and Larry Pegram Ducati.
I'll answer any technical questions - 415 491 5920.
Best regards -
Marc Salvisberg
(currently pleasantly experientially biased)
Factory Pro Tuning
415 491 5920
marc@factorypro.com
www.factorypro.com
Bigbore4
posted November 28, 2010 03:52 AM
2008, Feb. Dynojet just sent out an email showing other brands of dynos and tire slippage on those other dyno brands. They claimed the "they" have the "best traction" (arguing that implies that the "other dyno companies" haven't figured out to knurl a drive roller in 50+ years)......... I guess that they forgot to ask Dusty and the other DJ guys that ran their dj dyno at the AMA Races......... and when they loaded 2 people on a bike at Road Atlanta, they used one of the "largest dudes that I'd seen that weekend" as the second guy - With 2 guys AND super tightly strapped - it still slipped. It was a long weekend and I was napping in the truck w/ the AC on. Paul Riccio was in the passenger seat, eating lunch - He woke me up with "Awww... heck - Dynojet's got Traction Control." I opened my eyes, because I'd never seen dyno traction control, to see a ~300# DJ guy leaning over the back of the bike for more weight.......... still slipped when it hit the powerband.
In those youtube movies that were in that dj press release, they showed a bunch of "other" brand dynos with dj style "knurled" driver rollers, slipping - but - but! There was not a single youtube movie of the patented Factory Pro slotted drive roller slipping.
On the pateneted Factory Pro drive roller, you can even be doing a full throttle, Steady State test at 130 True HP levels - throw 32 oz of water on the tire / drive roller. It goes "whoop!" for an instant and then immediatly settles back into full traction. And that's even on an almost 15 year old Factory Pro drive roller!
Let's see the their movie of "DJ good traction" in a steady state test and a 32 oz dump of water on the drive roller on a 15 year old dynojet!
You'll never see it - because it's impossible.
Johnnycheese
posted November 28, 2010 05:25 AM
quote: Excuse me? Most of the DJ are inertia dynos and that's a fact. They have an optional eddie current. Big difference in cost. So, to correct you, they are not the same.
let me correct myself the DJ250 ( most of DJ's dynos now)is the same as the factory pro both use eddie current brakes
as I said the dyno operator makes more differance than the brand of dyno.
and yes I know how to use my dyno and sweeps are great but proper load control is king just look at my post.
Bigbore4
posted November 28, 2010 06:59 AM
I agree 100 % that a step test is way more useful than a sweep. The major difference between the f pro and the dj is the fact that the dj still has a very high inertia roller, along with the brake unit. Obviously the brake unit is going to be much more useful than a sweep with a heavy roller. And, yes, I'm sure that you know how to use a dyno.
Cheers
