motojoeyt
posted October 05, 2010 09:09 PM
Poll Question: ZX clutch problems?
Hi Guys,
I have a 05 ZX-12 (stock motor) with a 8 over arm, 2 down 4 up gearing. Im doing mid 1.5 60 foots leaving at 6grand and going wide open slipping the clutch. But I have broken frictions multiple times and even shattered a stock outer basket so I replaced it with a Muzzy. Any clue why I'm braking frictions? anyone try to put in a 14 basket in a 12? What is average material burnt away per pass? I'm going through .020 on my stack height ever 6-8 passes. Is this average?
Thank you in advance,
Joey
8.81@154 DOT/Pump full street bike
Poll Results:
0 votes (0%)
motojoeyt@hotmail.com
NOX
PMRA / TMRC Super Street 4022
posted October 05, 2010 09:30 PM
What set up are you running in the clutch?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
motojoeyt
posted October 05, 2010 09:40 PM
Hi NOX,
2.285 stack height, thickest steels (from kawi) throughout and heavy Barnett Springs. And when i last broke the frictions i couldn't even tell doing 1.56 60fts.
Thanks again Joey
SteddyTeddy
posted October 06, 2010 05:14 AM
Sounds like your slipping the clutch WAY TOO much to start with.
posted October 07, 2010 02:47 PM
Edited By: KZScott on 7 Oct 2010 22:47
too much slip im guessing
you might need to adjust your suspension or driving style to require less slip
what does the hub look like?
2000redrocket
posted October 07, 2010 05:29 PM
for me when i hammer mid 1.5 60fts i brake friction plates from time to time.
and i am full throttle clutch lever out by the tree. i my self only started braking frictions
when i started hammering it and getting mid 1.5s 60ft.
i am told the ones with a properly setup lock up do not brake frictions.
i go through my clutch every couple of weekends.
