BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: the snowflake NEW TOPIC NEW POLL POST REPLY
2000redrocket
posted September 01, 2010 03:11 PM        Edited By: 2000redrocket on 1 Sep 2010 23:12
the snowflake
here is what i think will be the last big change. every move forward tells you what to do next.
mathews
posted September 01, 2010 03:38 PM
Really hard to get one right without a data recorder.Engine driven(hays,mtc) are a lot easier IMO
2000redrocket
posted September 01, 2010 03:53 PM
i am logging. with a wego3. sofar so good for using cheep stuff.
gixxre750
posted September 01, 2010 03:58 PM
he means one that can record clutch data
Stuart Racing
N.H.R.A . Dragracing.
posted September 01, 2010 04:12 PM
Go for it Dennis.....2 arms and let it fly........
2000redrocket
posted September 01, 2010 04:32 PM
so to get clutch data vs what i am getting? i can see the rpm spike and the line to full enguagement rpm. and then the rest of the run.
Are you throwing the lever?
2000redrocket
posted September 01, 2010 04:35 PM
yup. and sometimes shitting my pants. (that was when i went with 4 stock springs to try it out. not knowing what it will do)
posted September 01, 2010 04:37 PM
If you are throwing the lever, rpm and tps are probably enough to tune it...
2000redrocket
posted September 01, 2010 04:44 PM
what i thought also but i am still on manifold air pressure.sort of the same thing with out the fine view of exactly how much. but i dump it so as soon as the map line goes up to the top i know i pinned it. i like the fact on using the time slip starting with that upward line to mark the different marker times.
though logging also shows one how much they suck.
NOX
PMRA / TMRC Super Street 4022
posted September 01, 2010 10:00 PM
Depends on how much you know of what you are doing..........
If you are challenged in clutch tuning, then a data recorder will help, if you know what is doing what.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
whitehendrix
fails!
posted September 02, 2010 12:44 AM
i really want a lockup.
not sure anything will fit my bike tho. should be able to mill my own from the looks of it.
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
NOX
posted September 02, 2010 04:28 AM
What bike do you have......
A zrx will run stuff from a zx11
We run a lock up in a zzr super gas bike, with parts from a zx11
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted September 02, 2010 02:26 PM
hes got the 7r
NOX
posted September 02, 2010 07:34 PM
I think someone makes a lock up for the 7 r........, or a slider.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
2000redrocket
posted September 03, 2010 09:28 PM        Edited By: 2000redrocket on 4 Sep 2010 05:29
well the last pass was a 1.59 60ft but still had to "get out of it" on the lock up> 2 arms aluminum bolts 17mm long> first pass though was a nice enguagment with the front still
on the ground pinned and a 9.60 flat with a 28.98 barameter.all other passes threw the front in the air at lock up> if i have to oil the clutch with a lube can every pass i may not go much farther with this for what i am doing. i will try this one weekend and if it works out i need to re group or get more oil in the clutch pack normally>
it will take more spring so the 60 will drop more. i am happy with that.
chavcat
posted September 04, 2010 04:04 AM
why would you need to oil the plates every pass?
2000redrocket
posted September 04, 2010 04:47 AM
i am thinking for it to lock up smoother. first pass (after i had it apart and made sure the plates were wet) it came in nice and smooth after that with out changing anything at all it threw the front up hard line someone added weight to the arms when i was not looking. i am at two arms aluminum bolts and no washers. can not get much liter with out grinding on the arms.
Stuart Racing
posted September 04, 2010 05:13 AM
Sounds like you still need to work on the spring static if the front is still lifting on launch....Leave the arms alone unless it is slipping on the top end of the run.....Might need a few more inch`s on the swingarm.....Or get it as low as possible....
chavcat
posted September 04, 2010 05:35 AM
Nox - any recommendations on the static setup here?
2000redrocket
posted September 04, 2010 06:10 AM
chav do not bother nox. we will get it. paul it is lifting on top not in the beginning. the arms are throwing it up when they start clamping. but i added shim and last pass was a 1.59 60ft and one throttle pump to keep the front down. i am close. i agree on the swing arm and lower to the ground.every time i get closer.
chavcat
posted September 04, 2010 06:38 AM
Is this a 6" arm?
2000redrocket
posted September 04, 2010 06:40 AM
no i only am at 4"
NOX
posted September 04, 2010 07:32 AM
Because of an improper lock up tune up, you don't have to do that when things are correct.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
posted September 04, 2010 07:35 AM
also, at that wheel base with a single stage, it is no problem if you have the chassis, clutch, and all working the right way.
I ran at about 63 to 64 inches with no front weight for a long time, with a single stage lock up.
There are many factors that control these things ,and some are sort of outside what you would think.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.25998687744141 seconds processing time
