BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Transmission Service NEW TOPIC NEW POLL POST REPLY
tcchin
posted August 31, 2010 10:32 PM
Does anyone have any recommendations for transmission service? I'm looking to have hard welding, up/down undercutting, heat treatment and maybe coating done to my S1000. I'd buy new OEM replacement parts, but they're expensive, unavailable and they would just exfoliate shrapnel like the original ones did.
posted September 01, 2010 03:01 AM
hey Tim
I don't know if he does all the stuff you want but lots of us have used this guy to great satisfaction:
"Mark Doucette,
R&D Motorsports
727 447 4552 9-6, M-Th, EST:
1632 N Hercules Ave Bldg G, Clearwater, FL 33765
Call him only when you have a "few minutes" to spare
a nice touch: he dremel/scribes yr initials onto all parts he touches/modifies.
ZRXDean
posted September 01, 2010 04:57 AM
What????? Please elaborate.
TRNorBRN6001
posted September 01, 2010 10:33 AM
Yep, I'd hit R&D first and then Robinson
TFA 200MPH CLUB MEMBER!
posted September 01, 2010 10:40 AM
R&D, as mentioned.
Stuart Racing
N.H.R.A . Dragracing.
posted September 01, 2010 12:28 PM
R&D too....Since my motor is apart at the moment I sat down and checked out my trans that R&D did for me.....Some really nice work..Nice machine work on the dogs for the back cuts,did some work on the shift drum also.....I sprung for the chromoly shift fork shafts too.....
tcchin
posted September 01, 2010 02:01 PM
Thanks for the referrals. Just spoke with Mark at R&D. That man is a wealth of information! As soon as I convince my rider to do a trans service instead of getting a new bike (and a whole new set of variables), I'll be sending Mark my trans and cases. Thanks again for all the help!
tcchin
posted September 01, 2010 02:04 PM
The stock trans would nearly plug the drain hole with metal fragments at every oil change. My oil change interval, BTW, is one race weekend. Those gears must be big to be able to spare that much metal.
osti33
posted September 01, 2010 03:47 PM
I'm a little late but I agree with everyone else. Mark at R&D is the man.
ZRXDean
posted September 01, 2010 04:51 PM
Holy crap TIm. Is this common on these bikes? Never heard this before.
I hear that R&D is great, and that you pay for it. I wanted a larger first gear, which Robinson makes, and ended up sending my trans to him, and I'm happy.
posted September 01, 2010 05:02 PM        Edited By: Shane661 on 2 Sep 2010 01:05
Mark makes you feel good about the coin you are dropping...and the results are great as well.
Soon I will post pics of the pro cut trans he did for me....gorgeous...
TRNorBRN6001
posted September 02, 2010 10:08 AM
What do you think might be the issue for your case? Did mark or you have any ideas. Clutchless shifts on a road coarse? Or down shifting at high RPM? Gear metal hardness?
tcchin
posted September 02, 2010 12:00 PM
In over a decade of racing at this level, I have never seen this kind of debris on the drain plug of an otherwise running motor. In roadracing, all shifting is clutchless, all downshifts are from high RPM. Over the years, some bikes have had slipper clutches while others have not. I can think of many things that could be the source of the issue, but without having seen the transmission yet, they're all speculative.
TRNorBRN6001
posted September 02, 2010 12:32 PM
I have so little experiece and have only seen a hand full of trannys go bad. The ones I have seen were from drag race bikes and usually had bent/worn/fatigued shift forks and shafts with the trans damage. It will be intersting to see what you and Mark have to say.
posted September 02, 2010 02:24 PM
+1
He did mine and dads winter 07/08.
tcchin
posted September 02, 2010 07:15 PM
So when you get your trans done, do you go full-boat (undercut, micropolish, microblue, shimming), or do you do something less?
posted September 03, 2010 12:30 PM
Tim,
somewhere i have the list of stuff i had done, i'll get it to you.
posted September 03, 2010 12:35 PM        Edited By: Shane661 on 3 Sep 2010 21:53
My 12R need a new 2nd gear, new shift forks...
I added:
Undercut
Nitrous Cut Shift Drum
Billet Shift Shafts
HD Circlips
(as best as I recall)
On the 14:
Several gears needed welded up
Undercut, with Pro Cut for Drag Racing (includes heat treat)
Nitrous cut shift drum
Heavy duty detent spring
Addional ZX-14 specific mod (I'd had to check the paperwork)
Of course, it all starts with a magnaflux and inspection. Our drag racing needs can be somewhat different than what you may need for road racing. For example, some undercutting can adversely affect downshifts.
posted September 03, 2010 01:50 PM
in mine, billet 1-4 output gears, with first being lower ratio(drag), HD clips, nitrous drum mod, back cut, new forks and billet shift shafts. havent messed with it since, but my blow up has caused a need to get it looked at...
0.24652981758118 seconds processing time
