BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Gear position with Dynojet hub NEW TOPIC NEW POLL POST REPLY
blueshark
posted August 14, 2010 08:49 AM
Any one using the gear position feature with the Dynojet hub on a 00 ZX12? I want yo use the feature to run nitrous later and possible change fuel trim for each gear. The hub has one wire to see gear postion so I assume it looks for resistance. The 12 uses a different wires for each gear and the manual says you will see 0V at the ECU. Any help will be appreciated.
0.2128119468689 seconds processing time
