BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: direct port dry NEW TOPIC NEW POLL POST REPLY
posted August 07, 2010 07:49 PM        Edited By: KZScott on 8 Aug 2010 03:50
direct port dry
we decided to change dads dry shot from a twin spray setup in the ram air tubes to this
used parts from a dynotune kit, nos kit, and some 1/8 ss line
Pretty Fast
posted August 08, 2010 08:46 PM
KZ u didn't want to use steel braided lines for this for reliability and the safety aspect?
blueshark
posted August 09, 2010 07:00 AM
Looks like he's using hard steel lines.
posted August 09, 2010 02:48 PM
these are 1/8 SS hard lines
NINJA12
posted August 09, 2010 09:19 PM
where are you jetting it?
are the lines stiff enough that they don't jump when sprayed? (don't need to be held in place)
posted August 10, 2010 12:34 PM
the jet is at the solenoid, like in the dynotune kit
they move a little, but nothing that worried me, they are quite stiff
Gixx1300R
posted August 12, 2010 12:49 PM
You need to run 4 jets with that type of setup
Halvefast
posted August 12, 2010 12:53 PM
Just curious as to why 4 jets,
is it because of the shape of the dist block?
ECTA Ohio Mile 195.132mph
Gixx1300R
posted August 12, 2010 01:56 PM
Yes that is correct. Nitrous is a compressible gas so 2 of the cylinders will get a little more NItrous than the other 2. If the jets are on the outlet you the dist block it is not a problem.
posted August 12, 2010 04:47 PM
how many jets are in your spray bars?
Gixx1300R
posted August 12, 2010 04:56 PM        Edited By: Gixx1300R on 13 Aug 2010 00:58
My spraybars use 1 jet but I CNC machine showerheads that are supplied with the kit. The showerhead divides the Nitrous and distributes it evenly to the intakes.
Halvefast
posted August 13, 2010 05:06 AM
Good info Thanks!
posted August 14, 2010 01:23 PM
thanks, i might have to get a shower head from you
this setup got the old man a 157mph today though with a .040 jet (250 pounds unsuited) he usually runs 144-146
Gixx1300R
posted August 14, 2010 04:29 PM
There is no need to get a showerhead unless you are dead set on running 1 jet. All you need is to do is get 4 funnel jets and some 1/8 x 1/8 compression fittings
posted August 15, 2010 11:31 AM
put the jets at the d block?
Gixx1300R
posted August 15, 2010 04:29 PM
the jets will go inside the fittings. I'll take some pics and post them for you in a day or 2
posted August 29, 2010 10:36 AM
any pics?
thx
0.24011206626892 seconds processing time
