BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: air box grommet ? NEW TOPIC NEW POLL POST REPLY
aliveagain
posted July 15, 2010 04:23 PM
air box grommet ?
The grommet for the access cover(one of three) to the air box is spinning in the frame. It doesn't look like it can be tightened up by compression. This is on a ZX12R. Any suggestions?
http://fiche.ronayers.com/Index.cfm/Module/Main/TypeID/26/Type/Motorcycle/MakeID/3/Make/Kawasaki/YearID/41/Year/2000/ModelID/4382/Model/ZX-12R/GroupID/137953/Group/Frame
part #92015b - Is there a way to tighten these up?
2fat2fly
posted July 15, 2010 06:29 PM
That's called a rivnut.There are special tools for installing and tightening them.You can cheat by using a 2" long bolt of the correct thread with a nut threaded onto it.Thread the bolt into the rivnut and tighten the nut while holding the bolt head.It will draw the rivnut tight.Be sure to use at least a grade 5 bolt so you don't break it while doing this.
aliveagain
posted July 16, 2010 01:28 AM
thank you !
2fat2fly
posted July 16, 2010 07:41 PM
Glad to help.
0.26297807693481 seconds processing time
