BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: PC tuning individual cylinders NEW TOPIC NEW POLL POST REPLY
posted July 05, 2010 05:44 PM
I think I started doing this by mistake tonight, started tuning low rpm with no load and was going well, idles much better, ect, but then i started having trouble around 4000 rpm 2% tps, it was running lean, and spitting popping ect and i added a bunch of fuel, however the power commander control center is not showing the % i added, its about 20 % lower than the cells in the map. did i accidently start tuning just one cylinder? the bike did die a couple times during my initial trying to get it to idle down (it wouldnt stay running below 2200, now its down to 1000-1200 where i want it) , so maybe voltage spikes did something?
posted July 06, 2010 03:23 AM
I did that one time with the USB, drove me nuts, took DynoJet to tell me what a dumass i was.
Johnnycheese
posted July 06, 2010 07:08 PM
IF YOU DO SPLIT THEM ADD 10% MORE FUEL IN 1 AND 4 THAN 2 AND 3
Dang sorry apout the caps
posted July 12, 2010 05:53 AM
Did you get it tuned, Scott?
posted July 12, 2010 02:02 PM
thx Johnny, i dont think ill try anything like that untill i get 4 EGTs tho
still working on it. one of the batterys i put in is no good, so ill be getting one tomm after work. the pc goes ape shit with low voltage, and the fuel pump doesnt seem to keep up without being on trickle charge for awhile. races were rained out on the wknd so no progress really.
posted July 13, 2010 06:36 PM        Edited By: KZScott on 14 Jul 2010 02:40
put a new battery in so i have 2 stock batterys running in parallel. it spun over really fast and fired up much nicer than "normal", so hopefully thats a gremlin out of the way. 2 cells on 1 battery were swelled out, and it read 11.5v. old good battery was 12.5v, new bat was 12.7v . ill try tuning tomm if the rain holds off.
posted July 18, 2010 02:34 PM
im not getting anything from my LMA-3. i shortened my wire from it so that may be the problem. my buddys LM-1 wouldnt pick up anything from it either.
bike was awesome to start all wknd at the track with 2 stock batteries. still 12v start, no need for 24v. didnt have to put it on a charger at all
0.34382200241089 seconds processing time
