BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: couple progress pics NEW TOPIC NEW POLL POST REPLY
posted May 31, 2010 05:47 PM
now at 60 in WB , what do you think?
btw, Karl I got the valves today thanks!!
posted May 31, 2010 06:10 PM
Looks great Scott!
aliveagain
posted May 31, 2010 06:15 PM
Looks a tad more than 60".
chavcat
posted May 31, 2010 06:20 PM
Looks good!
almost_les
posted May 31, 2010 06:36 PM
careful with that short wheelbase, it might try to lift the front end more than before
posted May 31, 2010 06:37 PM
I see this and it makes me want to put the sidewinder back on!
posted May 31, 2010 07:05 PM
thanks guys, this is turning out to be a lot more work than i planned, but its finally wrapping up
ive got lots of weight moved forward to keep the front end down with this setup
cant wait to get everything back from Jim!
i have a few little things left then its basically just the motor and tuning. I have a new hook up to put on my good rear rim(the 02 rim on there has my best worn out u soft for tuning runs) and i got a nice 60 series front from Ali to go on. then i can drop the fender a bit and then the forks in the triples the same amount. the big motor should sound awesome with the new (to me) Brock SW
Shane, you have the big 12 for a street bike, why not go all out with the 14 with a drag setup?
woppi
posted June 01, 2010 03:36 AM
looks nice !!!
you have to paint the voilet spring !!!!
why you dont demount that part ??? you dont need it ! you dont ride in the rain !!!!!
1st TFA Member / Austria !
2000 Limited ZX12R NOS
woppi
posted June 01, 2010 04:11 AM
my toy
posted June 01, 2010 02:30 PM
Maybe I will next year. But I still have a few personal demons that I am chasing, and I need the bike to be street and mile suitable...
posted June 01, 2010 07:03 PM
How does taking the resonators off help?
posted June 20, 2010 05:30 PM
man, what a big job test fitting for an exh bung...
dry fitting most of a motor lol
looks like ill have enough room just under the clutch cover at the start of the meg. so the wideband will basically point at the oil pan
rgeorge
posted June 20, 2010 08:54 PM
Trying to decide how to mount a five pounder is tricky isnt it? I ended up leaning mine slightly rearward. The way you have yours you should get every last drop of liquid nitrous from that bottle.
That long blue tail looks nice. Did you use colorrite paint? Ive got a new (to me) tail that I want to paint blue.
shiggsy
posted June 21, 2010 04:37 AM        Edited By: shiggsy on 21 Jun 2010 12:51
I understand that its not a good idea to have the O2 Sensor pointing down or below 9 or 3 oclock as condenstation can collect in it and kill it (thermal shock ) on startups.
EDIT: Actually I think I have mis-interpreted you direction of point, I thought your were going to come in from undeneath, with the cable end towrds the oil pan. Re-rereading I'm guessing your coming in at an angle from the top, sensor end pointing down towards the oil pan. Sorry, I'm thick.
posted June 22, 2010 01:42 PM
i think i have it in the best location not much room to spare!
I had a buddy paint it, he just got close (but it was cheap so i cant complain too much) its too dark under low light, but in the sun or a camera flash its pretty close because theres a lot of pearl in it that brightens it up.
the 12 over tail/ seat combo put the arm in good proportion to the bike, i like the stance
yes the O2 will point a little upwards, not down, not ideal, but better than at the bottom
posted July 03, 2010 07:37 PM
Made some noise tonight first heat cycle, check
Stuart Racing
N.H.R.A . Dragracing.
posted July 04, 2010 05:47 AM
Must be nice,lol......
posted July 04, 2010 04:27 PM
made some tire smoke . looks to be running super lean by the pipe. ill be hooking up the logger tomm and get a start on tuning
posted July 04, 2010 04:29 PM        Edited By: Shane661 on 5 Jul 2010 00:29
Damn Scott!! You've got that Shinko as flat as a slick!
Bike looks great!
posted July 04, 2010 04:51 PM
thanks, that one is just about done I have a new hook up on my good rim. WB measured 72 in, going to need something with more bite than the old u soft.
need to find a couple electrical gremlins, trim plastics, paint clutch cover... scare the locals with deafening open SW roar....
posted July 04, 2010 05:44 PM
nice to see both yours and yr Dad's bikes up and running
posted July 18, 2010 05:34 PM
That's the first pics Ive seen of the fuel tank. Looks good Scott!
0.22350907325745 seconds processing time
