BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: quick stroker crank question NEW TOPIC NEW POLL POST REPLY
posted June 19, 2010 07:25 PM
on a 12, the tight spots are under the #4 rod on the lower case, and the #3 rod to the starter clutch. is that it? I'm doing a 3x4 with stock rods. nothing is touching when i spin it over. min clearance of about 40 thou sound adequate??
NINJA12
posted June 21, 2010 06:57 AM
never had any clearance issues with the 4mm.
aliveagain
posted June 21, 2010 08:37 AM
With Falicon rods, I was hitting on #2 also on the back side.
chavcat
posted June 21, 2010 04:54 PM
Scott - I understood more rod to case issues are with Falicon/Carrillo/Crower rods vs OEM?
posted June 21, 2010 09:19 PM
1mm is good. Check it with the case halves snug, and make sure that nut clocking is not a factor. Set the nuts with a point "high" instead of a flat across.
chavcat
posted June 22, 2010 03:47 AM
Doug - can you clarify 'snug' with the cases?
posted June 22, 2010 01:36 PM
Im guessing tq'd?
this is what i ended up doing because Im paranoid of things hitting. I had about .032 to the starter gear before dremmeling
and the other tight spot now has tons of room
0.21342515945435 seconds processing time
