BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Link Pro NEW TOPIC NEW POLL POST REPLY
Ken 12r
posted June 06, 2010 07:34 AM
Link Pro
I have obtained a secondhand but never fitted Link Pro.There is no paperwork with it and the information on the net is a little sketchy at best.
Does anybody use one ?? and if you do,how much adjustment until you notice the difference ?? Which way is stiff and which way is soft. ??
For anybody who has never heard of a Link Pro its an adjustable suspension linkage manufactured in the USA for drag racing.
www.uklandspeedracingassociation.co.uk
posted June 06, 2010 10:17 AM
Nox runs one. as far as i can tell its a noticable range of adjustability. I would check sag before and after the install, then adjust it to give the same sag after. then play with it at the track instead of adjusting the spring. should be a lot easier
woppi
posted June 06, 2010 11:40 AM
we use one !
1st TFA Member / Austria !
2000 Limited ZX12R NOS
0.22357702255249 seconds processing time
