BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: hot starting and lean NEW TOPIC NEW POLL POST REPLY
2000redrocket
posted May 02, 2010 03:08 PM
when i start the 12 up hot it usually goes real lean and takes time to ritchen up.as you rev it up it goes more normal let it idle and leans out again.make a pass and it is normal.
i am thinking on getting a inlet air temp sensor and replacing it thinking it is giveing a odd reading when heat soaked from engine temp.
i do not think it is the collant sensor but i will not ignore the thought. if i let it go till the colling fan is on it does not go 15.5 to 1.
what do you guys think?
2000redrocket
posted May 03, 2010 04:19 PM
well no takers?
the ones with a zx12 on here, i did find my inlet air temp sensor was loose by about 1/2 turn.
posted May 03, 2010 05:05 PM
im thinking mine does that too, but i cant really remember...
krexken
posted May 03, 2010 08:44 PM
You should be able to test the sensors. Did this problem just start?
2000redrocket
posted May 04, 2010 01:41 AM
last year i noticed it
0.28557991981506 seconds processing time
