BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Nitrous wet kit Jetting? NEW TOPIC NEW POLL POST REPLY
posted April 11, 2010 07:58 PM        Edited By: KZScott on 12 Apr 2010 04:02
ok, so I played around with my holley blue fuel pump tonight. got some help on the land racing forum. reg is not a bypass, so i plugged the "return" line and put an adapter on the pressure line with a tiny hole to replicate 4 fuel jets. (i think i drilled a .060 hole)
I set flowing pressure to 10 psi. Last yr I had the NOS pump which is not regulated and about 3 psi
I want to start with 80 hp, so 24s in the Nitrous side. I try to tune the bike to about 12.8:1 AFR NA, I want it running about 12:1 on spray.
What size fuel jets do I want?
thx!
btw, http://www.coldfusionnitrous.com/calculator.html says I need 20s
06redzx14
posted April 12, 2010 05:24 AM
small ones. check the nx website
posted April 12, 2010 05:40 PM
http://www.ny-trex.com/calculator.php
says .020 also
http://www.nitrousexpress.com/Instructions/4cyl_dpjetting.pdf
says 20s will be a bit rich
I think ill try the 20s. had 28s with low pressure. high pressure is supposed to be more consistant
0.21674513816833 seconds processing time
