BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 180hp BMW?!?!?: anyone see anything wrong with the hp/tq curves? NEW TOPIC NEW POLL POST REPLY
posted December 17, 2009 01:59 AM
maybe it's just me, but hp & tq don't seem to jive...
ZRXDean
posted December 17, 2009 06:20 AM
Wow, that doesn't make sense. In this universe, equal torque at equal rpm should lead to equal hp. What magazine published this graph?
posted December 17, 2009 06:38 AM
i think it is MCN, but it may be the Onion
posted December 17, 2009 07:22 AM
*BMW and Honda figures recorded in rainy conditions - BMW tested in "slick" mode
WTF, 1/4 mile, braking and top speed testing in the rain???!?
posted December 17, 2009 08:40 AM
quote]
OEM traction control????
posted December 17, 2009 08:41 AM
It's probably just a multi-map selector...something like the Suzuki Dmode, or whatever you call it...
posted December 17, 2009 08:55 AM
looking at the tq curves; bmw, suz, kaw hp all should be displaying the same hp at 11500rpm... bmw is up 20hp at 11500???? WTF????
Makes no sense, you're right....
Phantom13
posted December 17, 2009 09:46 AM
When has BMW ever put out honest info on their bikes? Anyone remember the busa beater that never was? Good ol BMW, what will they come up with next?
"The only place Success comes
before Work is inside the Dictionary."
  Ignore this member    Click here to visit Phantom13's homepage.
tcchin
posted December 17, 2009 11:02 AM
I've seen similar hp figures published in RRW&MT, I believe. Torque and hp are not independent values.
Ricksgsxr
posted December 17, 2009 11:04 AM
Who does? but this one seems to be a bit different with the HP claims seems to be a strong one. RR World got 179hp , Arrow and Akrapovich have similar numbers, MCN which I do not put alot into thier claims but do have a video of the dyno run ( I know means jack shit ) but BMW may just have a strong runner and makes sense when they are targeting the Big 4 litre bikes.
Will wait and see what transpires when posts start popping up from new owners.
Maybe Fish has one on order?
Rick
posted December 17, 2009 11:08 AM
show me the 1/4 mile trap speed. those dyno numbers dont scare me
posted December 17, 2009 01:49 PM        Edited By: Shane661 on 17 Dec 2009 21:50
As Karl said...
How is it that it makes 20 more hp at the same rpm, but has the same torque at that rpm as the other bikes?
That's simply not possible.
almost_les
posted December 17, 2009 04:39 PM        Edited By: almost_les on 18 Dec 2009 00:42
look at 11,000 rpm. the torque shows about 78ish ftlbs of torque. plug this into the equation hp=(TQ*rpm)/5252 and you get 163ish hp. now lets look at it backwards: TQ=(HP*5252)/rpm. if you make 180hp at 11,000rpm you need about 86ftlbs. what is shown on the hp chart is total bullshit
posted December 17, 2009 07:16 PM
Not Right, clearly. It's the mysterious .Bruntingthorpe effect
WARBIRD
posted December 18, 2009 07:54 PM
Went to the Akrapovic site and it looks like that hp peak occurs at a lot higher rpm (13200)than the MCN chart indicates(11000). That line should be moved farther to the right......the overlay is not right. That changes things a little.............
Doesn't that make sense? They just blew getting all the graphs overlayed properly??
I'd Rather Be Roadracing.
WARBIRD
posted December 18, 2009 08:10 PM
If you take that line by the peak of the curve, and drag it over to 13200, wouldn't the graph look about right? Looks like it would be making less hp and tq at 8500 and below.........
WARBIRD
posted December 18, 2009 08:11 PM
Than the other bikes.............
tcchin
posted December 18, 2009 09:46 PM        Edited By: tcchin on 19 Dec 2009 06:01
I think the whole report is suspect. The caption says that the Yamaha cross-plane motor rules the midrange while the BMW makes the most power. From the power chart, it appears as though the Honda rules the midrange from 5.5-8.5k (relative to the other Japanese marques), yet that isn't reflected in the torque chart. As I said before, power and torque are not independent values - they are linearly dependent - so if you're making more torque at a given rpm, you're also making more power.
Curiously, at 7k, the highest torque curve (Yamaha) comes close to matching the highest power curve (BMW) with ~80 lb-ft and ~107 hp. After that, the slope of the R1 torque curve begins to go negative, while the slope of the BMW power curve appears to go more positive, which does not match.
Another oddity is that there are two torque traces that redline before 12k, yet all of the power traces go well beyond 12k before hitting redline.
WARBIRD
posted December 21, 2009 08:05 PM
Was over at gixxer.com.....MCN tried to fix their dyno charts but still goofed them up. However I think the Beemer is going to trounce everyone else in the hp wars.......
http://www.gixxer.com/forums/showthread.php?t=234126&page=19
WARBIRD
posted December 21, 2009 08:08 PM
Don't know if this will work but I'll give it a try. Hope you can see the pic......
tcchin
posted December 21, 2009 08:35 PM
I don't know if the BMW will spin up to 14k... And the other redlines are still all screwed up.
WARBIRD
posted December 21, 2009 08:59 PM
Like I said above, they still goofed the graphs up.......but at 13,200, it's really pumping out the hp............
Someone will have one on the dyno soon.........like Kerry at AreaP..........then we will know the differences between it, the Ducati, the Aprilia and the Japanese bikes.........
ZRXDean
posted December 22, 2009 05:38 AM        Edited By: ZRXDean on 22 Dec 2009 13:38
Hard to believe that MCN screwed up the correction too, shoddy work.
Hotlinking their pics, the BMW may spin to 14, and uses a similar ramair design as KHI;
tcchin
posted December 22, 2009 09:25 AM
I can't believe that they scaled the plots in the first place, and that they were even able to "correct" them. They must be using a different version of Excel than me, and they certainly aren't using WinPEP!
RRW&MT has dynoed this bike and got about the same ~180hp. I hope that 14k redline is real. That would be impressive if it were. My engines get really angry with me when I try to make them turn 14k... I assume that the stroke is very short on this motor to keep the piston speed in check.
WARBIRD
posted December 22, 2009 12:20 PM
Here is a little video with the motor singing it's song..........
0.26567506790161 seconds processing time
