BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: logging pressure. what transducer? NEW TOPIC NEW POLL POST REPLY
posted November 26, 2009 01:15 AM
Im convinced that logging oil pressure is going to be the thing to do drag racing a stroker motor next yr. (strongly suggested by Karl).
I think a 0-100 psi, 0-5 volt linear transducer would be what Im after. My LMA-3 can power a 5v sensor if need be. Ill be running the stock oil pump, but not shimming the relief valve(unless it reads way low).
doing some searching on the Innovate forum and google turned up a wide selection of suggestions, with a wide range of prices.
what do you guys suggest?
thx
posted November 26, 2009 05:17 AM
Scott,
this is the one i use for oil , fuel pressure
be sure an use flexible mount to the motor.
0-100 PSI Sensor - #RTD-WB-762
1/8 NPT, 12 Volt Power, 0-5 volt output.
For use when measuring Oil Pressure, Fuel Pressure, Water Pressure, etc..
Weight 1.00 lbs
Price: $110.00
http://www.innovatemotorsports.com/xcart/product.php?productid=16202&cat=0&page=1
rgeorge
posted November 26, 2009 11:01 AM
Here are some choices:
http://www.egauges.com/vdo_sgrp.asp?Subgroup=Pressure_Sender
The cheap senders are bulky, but I was able to mount one for my pressure gauge in place of the factory oil light switch.
I tapped into the signal wire to my oil pressure gauge and log that voltage. I really like having a pressure gauge on the bikes dash so I can watch for the pressure drop during warmup.
The best senders are three wire like the one Karl recommended above. But for this application, you don't need a lot of accuracy . A single wire, resistance to ground sender works fine. Thats what my gauge uses.
posted November 26, 2009 12:03 PM
X10!
It's another health check,
pressure drops to about 20psi on heatsoaked motor (full syn oil)
posted November 26, 2009 08:33 PM
thanks guys!
Rob, do those give a 0-5 v signal? Im looking at a few of them and they only have 1 or 2 wires not 3
osti33
posted November 26, 2009 09:07 PM
I use the same one Karl uses. Like Karl says use a flexible mount.
posted November 27, 2009 11:47 AM
vibration kills them eh?
plenty of hydraulic hoses kicking around, i can make up a short one easy enough with pipe fittings
woppi
posted November 27, 2009 12:36 PM
i use a oil gauge with an pipe
oil gauge is at the right side fairing / air intake
1st TFA Member / Austria !
2000 Limited ZX12R NOS
posted November 27, 2009 01:55 PM
Gauges are worthless while racing. Use a big red idiot light with a 40 psi or so threshold. The data will tell you what's going on, but only the light MIGHT save your engine.
posted November 27, 2009 03:13 PM
great idea!!!!
posted November 27, 2009 03:26 PM
that is a good idea! What kind of pressure are you guys seeing at around 5000-5500 rpm? (launch rpm)
posted November 27, 2009 11:00 PM
55-60-ish
posted November 27, 2009 11:13 PM
a big idiot light at 40 would be ideal now to find the switch...
psycho1122
posted November 28, 2009 06:46 AM
I am a firm believer in the "Change Engine" red light(s).
0.27239990234375 seconds processing time
