posted October 30, 2009 12:02 PM
Edited By: entropy on 30 Oct 2009 20:03
pressure sensor, TChin beat Innovate to it
My heap was eating oil pressure sensors, so Dr. Chin advised me to take it off the direct mount on the motor, mount it somewhere else using flexible tubing. I did that and voila, no more dead sensors.
Last night i opened a package from Innovate containing a new pressure sensor (for fuel pressure), and noticed that now Innovate/RTD has a new note in big, bold red letters:
"Note: Sensor warranty is void if sensor is directly mounted to the engine block. Use appropriately rated line/hose to isolate the sensor from extreme vibration."
cool
Tim Chin beat em to it
osti33
posted October 30, 2009 12:36 PM
Mine ate a couple of oil pressure sensors too. I have a third one mounted in the same place. I'll move it before I put the engine back in the bike.
Thanks!
tcchin
posted October 30, 2009 01:34 PM
Now if only they can make their xd-16 gauges last more than three minutes...
posted October 31, 2009 10:28 PM
quote: Now if only they can make their xd-16 gauges last more than three minutes...
Tim,
once I got the plug situation sort of sorted out, my XD-16 has performed fine, what's up w/yrs??
Karl
tcchin
posted November 01, 2009 09:48 AM
The first time I used it, it would work fine with the bike on the stands, but would stop working within ten seconds of rolling out of pit lane. After the third track session, it would not power up again. I tried several different power sources, and still could not get it to power up. Once it was removed from the rest of the LM-1/LMA-2 setup, the system worked normally again and my data quality improved dramatically. I'm waiting for Innovate to send me an RA number so I can have it repaired under warranty.
posted November 01, 2009 03:53 PM
Tim,
you know electronics as well or better than anyone here.
It must be broken, Innovate will make it good.
On the other hand, the XD16 is just about the same diameter as a sledge hammer...
tcchin
posted November 01, 2009 09:20 PM
I'm thinking maybe some microwave reprogramming is in order. What do you think, about 15 minutes on high?
