BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Valve Seat Contour & Profile ? NEW TOPIC NEW POLL POST REPLY
WRECKSHOP
posted October 14, 2009 02:29 PM
Which is the best angle, shape, contour or radius ? Which one is the most used and which one makes the most power ??? Cylinder head GURU'S chime in please.....
osti33
posted October 14, 2009 03:21 PM
Good luck!
Shop's spend thousands of dollars devloping cutters. I don't think many are going to just give that information away.
But I could be wrong.
posted October 14, 2009 07:05 PM
just get Jim to do it, worked for me
tcchin
posted October 14, 2009 09:39 PM
+1
Y2KZX12R
CompetitionCNC.com
posted October 15, 2009 06:09 PM        Edited By: Y2KZX12R on 16 Oct 2009 02:26
I have designed many cutter inserts for all sorts of engines.
This is one that I designed and works well for the stage 1 Busa... sorry I've removed the data but you get the general shape. I can tell you that .005" in seat widths and a change in radius of only 10% can make the difference between good and junk.
Basically its a balancing act between homogenization of the fuel and air flow. Angles help homogenize the fuel by causing flow separation and turbulence. A radius valve job flows more air on the flow bench. (usually) So If you can flow a lot of air yet induce a separation for better homogenization, the BSFC goes down and power goes up.
And that all I'm gonna say on that.
Y2KZX12R
CompetitionCNC.com
whitehendrix
fails!
posted October 15, 2009 06:15 PM
that explains it all!!!
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
WRECKSHOP
posted October 16, 2009 06:23 AM
Yes it does and thanks Mr. Y2KZX12R.....Thats basically all i was asking for, not anyone's particular secret or cutter profile data....
0.21015691757202 seconds processing time
