BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: filling your own nitrous bottles NEW TOPIC NEW POLL POST REPLY
posted August 20, 2009 07:19 PM
do any of you have expirience filling your own bottles from a larger one? (no fill station) my nitrous guy was telling my i should get a 10 or 15 pounder and just use that to top up my 2 pounder. i guess i put the little one on ice, and "pour" in the nitrous from the bigger tank. as long as theres no siphon tube of course. i have access to a 10 pounder....
thx
06redzx14
posted August 20, 2009 07:31 PM
stick the small bottles in the freezer. heat the big bottle. we only fill the bottles like this from empty
Halvefast
posted August 20, 2009 07:51 PM
I've had great luck just topping off the 2.5lb bottle.
You should have 2 smaller botlles one for the bike other in cooler.
And a good scale and a safe way to warm the mother bottle to add pressure,
try not to work with it over 1200-1300psi. Iv'e been able to get 2.8lbs in the bottle this way.
ECTA Ohio Mile 195.132mph
kawasakijockey
posted August 20, 2009 07:52 PM        Edited By: kawasakijockey on 21 Aug 2009 04:09
Just as he said.
You can top off the bottle if it has some already in it by first knowing what the total weight is full. Scratch that number into the bottom of the bottle so you will know how much to fill it to. I do mine like this all the time.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
Stuart Racing
N.H.R.A . Dragracing.
posted August 21, 2009 05:10 AM
x2...Worked perfect...
posted August 21, 2009 04:17 PM
so i NEED a scale to top off the small one?
thx
Stuart Racing
posted August 21, 2009 04:24 PM
OH YA....I used one of those potal scales with the big dial on the front of it.....I could even weigh the mother bottle to see how many fills I had left in it.....It`s limit was 49 lbs....
shiphteey
posted August 22, 2009 08:52 AM
They have fishing "hanging" scalaes, I use those for my smaller bottles. Not AS precise on the 10LB bottle but works for what I need to do.
Gemini Motorcycles
posted August 22, 2009 12:27 PM
thx guys
posted August 24, 2009 11:41 AM        Edited By: VincentHill on 24 Aug 2009 20:20
The Guys that do not cool the small bottles are losing at least 1/2 pound of NOS! I put the small bottles right after a run when they are already cold into Ice Water. I have a Warm up Jacket that I wrap around the 10 pound Bottle that Hooks to the 12 Volt Battery. I get about 2.5 pounds in the 2 pound Bottle and 3 pounds into the 2.5 pound Bottle and it happens Quickly!
Here is what I use and cost about $20.00 also good for your Luggage
http://www.amazon.com/Ultrasport-50-Hanging-Digital-Scale/dp/B001MXMUXE/ref=sr_1_8?ie=UTF8&s=hpc&qid=1251143286&sr=8-8
Here is the Heater Wrap for under $50.00
http://cgi.ebay.com/ebaymotors/Nitrous-Bottle-Heater-NEW_W0QQitemZ200302496188QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item2ea2f589bc&_trksid=p4506.c0.m245
Put a couple of Clips to attach to the battery of your van or truck and a Long 5 foot Hose
posted August 24, 2009 01:15 PM
great info, thx!
zrexpilot
posted August 25, 2009 08:00 AM
Like everyone says cool the small bottle either in ice or in the freezer and depending on temp outside you can just leave the big bottle in the sun, becarefull not to heat the big bottle up too much, a guage on it would be good also to see the pressure, or you can even just heat it up with a heat gun. You can overfill the small bottle very easy and it will tend to pop the pop of valve it left in the sun.
0.21688604354858 seconds processing time
