BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Hays Clutch NEW TOPIC NEW POLL POST REPLY
NOX
PMRA / TMRC Super Street 4022
posted August 17, 2009 05:35 AM
Hays Clutch
Its on the way........
I can't wait to get to testing it.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
06redzx14
posted August 17, 2009 12:07 PM
be careful when trying to use it in hand slider mode. we've already broken 1 clutch rod
NOX
posted August 17, 2009 03:21 PM
Hand slider? You mean multistage mode? I can probably figure what caused it.........
What bike did you have it in? When you say clutch rod, do you mean pull rod?
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
06redzx14
posted August 17, 2009 06:00 PM
when you get the instructions you'll have an option to set up as both a slider and hand clutch. you have to use the stall springs to set the rpm and use the pull rod to disengage the clutch as if it were a regular hand clutch
lilmikef
posted August 17, 2009 06:05 PM
Sweeeeettttt.............. My Cuzz is Running one & Ive Rode a few Bikes with em?????? Ur Not going 2 B disappointed.........
Heres a Video of a Turbo Bike I Run With Da Gann Clutch!!!!!!!
[URL=http://s92.photobucket.com/albums/l9/lilmikef/misc%20video/?action=view&current=Burnoutturbo.flv][/URL]
[URL=http://s92.photobucket.com/albums/l9/lilmikef/misc%20video/?action=view&current=TopSecretPass.flv][/URL]
Broke ass dragracer!!!
  Ignore this member    Click here to visit lilmikef's homepage.
lilmikef
posted August 17, 2009 06:08 PM        Edited By: lilmikef on 18 Aug 2009 02:12
Try This????????? Dont Know This Forum?????
06redzx14
posted August 17, 2009 06:49 PM
we were lucky enough to get the second unit machined. you'll definately have one of the first 5 in the country on a zx12
NOX
posted August 17, 2009 09:34 PM
Doug Ray has one, Paul Stuart will have the other......, you have one, and that leaves two more........
Doug has not installed his.......
I understand what you are talking about, I think you may have had too much weight on the arms for that rpm app.
I may be wrong, I gotta get my hands on one. I have tuned the Gen II's, but have not laid hands on a gann or Hays.
I am really looking forward to it.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
Stuart Racing
N.H.R.A . Dragracing.
posted August 18, 2009 05:07 AM
Mine should be here before the end of the week.....
Did the rod break at the end of a pass or at the stating line.....
It should be a nice peice once figured out.....Can`t wait....
06redzx14
posted August 18, 2009 05:12 AM
it broke on the lift. the owner thought it would feel like a regular clutch, but it won't depending on how much stall spring pressure you apply. he is using the medium springs turned down so that the slider engages at a higher rpm which in turn leaves the clutch a little disengaged until it reaches that rpm so it doesn't require too much from the handle to fully disengage. I hope this makes since. Just the way I see it sorry for the lack of technical terms
Stuart Racing
posted August 18, 2009 05:35 AM
On the lift...You mean at the finish line where he pulled in the lever.....
Stuart Racing
posted August 18, 2009 05:38 AM        Edited By: Stuart Racing on 18 Aug 2009 13:40
In slider mode you shouldn`t need to pull the lever in at all if setup right....
I never pull my lever in at the end of a pass untill speed/rpm`s are low....
NOX
posted August 18, 2009 06:00 AM
Yeah, on any pull rod type clutch, you DO NOT pull in the clutch lever at high RPM (slider type/ Hays), or wheel speed, (Gen I type single or multi stage lock up)
Unless I am reading wrong. First time I thought he meant they were breakin on the starting line......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
Stuart Racing
posted August 18, 2009 06:13 AM
Shouldn`t be a whole to get figured out if the stall springs get set right....With us running stock motors we/me won`t be spinning the tire past 330' when it locks up....
2 day turn around on Tim tranferring parts from one to another so it won`t be long....New trans., new clutch system yee haaw.....
06redzx14
posted August 18, 2009 06:19 AM
on the lift as in it never made it out the shop LOL. the owner had a multi stage in it and was looking to have the feel of a clutch. we have it all figured out now
NOX
posted August 18, 2009 06:29 AM
So what was the problem? There is no reason it should have broken the rod just up on the lift.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
Stuart Racing
posted August 18, 2009 06:33 AM
LOL.....Ya got me on that one ......So how/when did it break the rod.....
06redzx14
posted August 18, 2009 06:45 AM
you only need about an 1/8 inch lever movement to fully disengage the clutch. we adjusted and adjusted and adjusted til we had too much tension on the rod and the clutch wouldn't engage, but we didn't know because the bike was on the lift. one squeeze then pop. broke the head right off
NOX
posted August 18, 2009 06:49 AM
Someone must have been used to a HUGE amount of clutch pressure........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
06redzx14
posted August 18, 2009 07:15 AM
you got it! it was really just a simple mistake that cost another week on the project. it's a 1290 with a big wet shot
Stuart Racing
posted August 18, 2009 12:24 PM
I am going to use mine primarily in slider mode......I`ve ridden several slider dragbikes and loved it.....Should be alot easier on parts to....Well my lockup was ALMOST setup like a slider anyways......A 2step would really come in handy with this setup if it`s legal in the class you run in.....
posted August 18, 2009 02:14 PM
Sheesh.....
Everyone is getting LAZY nowadays???
DO WORK Son !!!!!
0.21114182472229 seconds processing time
