BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: chamfering main bearings? NEW TOPIC NEW POLL POST REPLY
posted August 15, 2009 10:19 PM
Seems like I had a brain fart and missed the discussion on chamfering mains.
Osti had good luck doing it, and my mains look like Ryan's "before" pix.
Any tips?
chavcat
posted August 16, 2009 03:09 AM
Karl - I was told by a good engine builder this is what he does on all stroker motors to help keep the bearings alive.
Y2KZX12R
CompetitionCNC.com
posted August 16, 2009 03:53 AM
Got a pic? Is the edge of the bearing rubbing on the fillet radius on the journal?
Y2KZX12R
CompetitionCNC.com
posted August 16, 2009 05:36 AM
i will go look at them right now!!
posted August 16, 2009 05:51 AM
i looked at several main shells carefully under magnification and could see no evidence that the sides of bearings are rubbing on the fillet of the crank. In fact i was surprised to see a very pronounced chamfer built into the shell, i'd never noticed that before. I then compared the used shell to a new one and they seem the same.
Y2KZX12R
CompetitionCNC.com
posted August 16, 2009 05:55 AM
Then your ok with the mains.
How about the rod bearings?
Y2KZX12R
CompetitionCNC.com
Y2KZX12R
CompetitionCNC.com
posted August 16, 2009 06:02 AM
This very issue becomes EXTREMELY important on our SB2.2 engines with piston guided rods.
The connecting rods don't touch the crankshaft or each other at all. (V8, 2 rods on one crank journal)
The pistons are locating the connecting rod at the pin end. The big end just floats on the journal.
So you could see how a rod bearing rubbing on the fillet radius of the crank would be a MAJOR problem.
Y2KZX12R
CompetitionCNC.com
posted August 16, 2009 07:00 AM
rod bearings look as good as they ever have.
I'm guessing i could re-use all bearings, but since I have some in stock, i'll replace em.
0.24487709999084 seconds processing time
