BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Muzzy hi pressure shifter - solenoid location? NEW TOPIC NEW POLL POST REPLY
posted July 13, 2009 02:55 AM
I see some folks mounting the solenoid directly to the piston assembly, and other folks mounting it like the Muzzy directions show, near the regulator bottle.
Right now i have mine near the bottle and it shifts fine, not as "snappy" as my Dale Walker PS-3 shifted, but it does shift reliably.
Any comments here?
I am tweaking stuff in prep for Loring 1.5mile and might as well set it up the "right" way.
chavcat
posted July 13, 2009 03:51 AM
Karl - MIne is fine near the regulator however there clearly is a trend towards mounting on the ram
posted July 13, 2009 04:45 AM        Edited By: Shane661 on 13 Jul 2009 13:25
As far as I can tell, there would be no functional advantage to mounting near the bottle.
Advantages to mounting on the ram would include quicker action, and less likelyhood of leaks. I have mine mounted to the ram now.
TRNorBRN6001
posted July 13, 2009 05:22 AM
I have mine next to the bottle in the hump as per instructions, but I do believe JC set Ralf's up next to the ram. Give him a call and see what he has to say.
TFA 200MPH CLUB MEMBER!
posted July 13, 2009 06:14 AM
thanks for the input!!
I'll call Cheese tomorrow at 6am (when i get updates)
As i said above, mine shifts fine, but kinda lazy; i LOVED the way the Dale Walker hit.
One time i measured the distance between tire marks on the 1-2 shift and it was 6" with Dale walker; Muzzy is more casual, but i never measured it.
Another benefit to moving it to the ram is a lil less "junk in the trunk", more room is good.
kawasakijockey
posted July 13, 2009 06:26 AM
The advantage of getting the solenoid close to the ram is when bottle pressure gets lower it still can put enough volume at good pressure to the ram to make a quicker shift which means less delay and kill time. That is why your shifts are lazy. If your regulator is set at 150psi and you have 2ft of line from your sol. to the ram, the pressure that actually moves the ram is going to be substantially lower than 150psi because of how much volume goes through the line for the 50-70miliseconds the solenoid is open.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
NOX
PMRA / TMRC Super Street 4022
posted July 13, 2009 06:52 AM
The makers of those type systems..., will tell you, you want it as close to the ram as possible........,
mount it on the ram. to heck with that muzzy set up........, it also leads to liquid getting in the valve.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
almost_les
posted July 13, 2009 11:03 AM
+1 for mounting it on the ram
posted July 13, 2009 12:40 PM
on the ram since day one, WITH a really long huge(6an) air line. setup according to the DR
ive never had a problem with the air part as long as i have my electronics working.
posted July 13, 2009 11:19 PM        Edited By: entropy on 14 Jul 2009 07:50
hmmmmm
i have my ram mounted horizontally, doesn't seem to be any easy way to mount the solenoid on the ram. won't fit on the motor side.
does anyone have a pic of it mounted on the outside? seems like a male-male NPT elbow might work.
posted July 14, 2009 02:55 AM        Edited By: Shane661 on 14 Jul 2009 10:56
NOX
posted July 14, 2009 06:18 AM
Thats pretty much the ticket.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted July 14, 2009 07:08 AM
Air shifters.....we dont need stinkin air shifters!!!
posted July 14, 2009 08:56 AM        Edited By: entropy on 14 Jul 2009 16:56
Shane: that lil elbow is what i need! can you fax me one?
CR: who needs air shifter?
ME!
my left leg/foot cannot footshift while in a tuck, no flexibility.
besides
Airshifters are COOL!
posted July 14, 2009 09:06 AM
I ordered mine from Mcmaster Carr..
posted July 14, 2009 10:03 AM
I am a big fan of McM-C but i'm thinking i can get one at Home depot
kawasakijockey
posted July 14, 2009 10:07 AM
Seriously doubt it. A Parker Store might have it if you have one local.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
posted July 14, 2009 10:41 AM
I use McMaster because it is easy...I get everything next day from the NJ warehouse since I am close.
posted July 14, 2009 01:30 PM        Edited By: KZScott on 14 Jul 2009 21:37
I just turned the ram sideways. let me see if i still have a pic....
NOX
posted July 14, 2009 02:54 PM
I do the same thing........,
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
almost_les
posted July 14, 2009 04:37 PM
make that three
whitehendrix
fails!
posted July 14, 2009 09:06 PM
haha, well, from someone who comes from the industrial control field (including pneumatic/hydraulic controls) thats a standard practice in any "good" setup. less to go wrong as well. the quick connects and hose become the weakest link then.. more connections and plastic line suck. slight bit more physical shock to the spool valve (which is what that technically is..) but they're pretty much designed for it anyway.
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
narider
posted July 15, 2009 07:54 AM
The advantage to mounting the solenoid close to the ram has been stated and proven. The advantage to it not being a direct (hardpipe) mount is that output testing is quick and easy (be it co2, n2o or standard compressed air), by keeping a quick release gauge on hand to show post solenoid pressure (it is however one more place to leak as WH stated if you don't have good mounting and quality connectors).
Todd
  Ignore this member    Click here to visit narider's homepage.
0.2511670589447 seconds processing time
