BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: cylinder spacer leak NEW TOPIC NEW POLL POST REPLY
aliveagain
posted June 10, 2009 07:04 PM
I've had a constant leak ever since I started the motor up.Is there anyway to seal up the cylinder spacer without pulling the motor and disassembling?This is on a 2000 zx12r.
posted June 10, 2009 11:27 PM
pete,
that's pretty weird, i don't use any goop on the spacer + base gaskets and have never had a leak.
i dunno how you'd seal it without taking it apart, maybe some JB weld on the area?
aliveagain
posted June 11, 2009 04:08 AM
It's more of a weeping leak where I will get a 5" puddle under the bike if it sits for awhile yet won't do it if on the stand straight up.
posted June 11, 2009 04:56 AM
I guess it is draining the head??
posted June 11, 2009 06:34 AM
are you sure it is the spacer and not the valve cover oil that can collect at the ridge at the spacer?. Did you use some kind of "SCRAPER" on the case or cylinder that may have ruined the surface? Did you use a NEW Gasket when rebuilkding the engine? If you used the same one and did not use it on the same side that could also cause this!
0.34325385093689 seconds processing time
