BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: drilled clutch hub? NEW TOPIC NEW POLL POST REPLY
moonzx12
posted October 08, 2002 04:59 PM        Edited By: moonzx12 on 8 Oct 2002 18:18
drilled clutch hub?
Was this much drilling needed in the hub?
Plan on doing the puller mod with 2.0 steels
krexken
posted October 08, 2002 08:25 PM
I doubt anyone knows for sure. Basically all your doing is giving the oil a place to escape from the inside of the hub rather than run over the outside edge of it. Hopefully most of it will pass through the holes and onto the plates. I personally don't think you can have too many holes nor do I think hole diameter is that critical.
0.30589509010315 seconds processing time
