BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: engine transporting NEW TOPIC NEW POLL POST REPLY
aliveagain
posted May 06, 2009 06:45 PM
engine transporting
It is getting close to the motor being done.How have you guys secured a bike motor in the back of a truck so it doesn't bounce around?Conn. is not known for it's smooth roads and I just want to make sure it doesn't roll or bounce.They said they could wrap it up with cardboard but I want to weigh all options.Any experience?
posted May 06, 2009 06:57 PM
Tire works well, or a simple 2x4 box...
posted May 06, 2009 07:00 PM
I screwed a 4x6 to a small pallet, the 4x6 was to level the engine out under the oil pan, and ratchet strapped it down... worked well.
osti33
posted May 06, 2009 07:28 PM
Me too. Strapped to a pallet. Worked like a champ.
whitehendrix
fails!
posted May 06, 2009 09:31 PM
+1000 on using a pallet.
small blocks to support it and bolt it to are a good idea, as is a strap of some sort..
i've used a box stapled to the skid as well.. a box big enough to encase the contents.. open the bottom of it and fold the tabs out, slip the box over with the top closed up and taped, then staple that bad boy to the skid and shrink wrap it.
keeps prying eyes from prying and keeps it safe and clean. a bid skid with the motor dead center will almost be impossible to flip.. they'd have to purposefully do that.
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
posted May 06, 2009 10:09 PM
Pete,
Are you just gonna pick up the motor at the builders, put it in a pickup, then drive it home?
If so, it doesn't have to be upright on the oil pan. Tip it fwd onto a tire or a pallet.cardboard, strap it down. No drama needed.
TRNorBRN6001
posted May 07, 2009 05:27 AM
Yep, old tire or pallet work great. Paint stores have a ton of pallets. I usually just put mine in the front seat and put the seat belt on it. I'll reach over every once and a while to caress it, just like my old lady!
TFA 200MPH CLUB MEMBER!
NINJA12
posted May 07, 2009 06:27 AM
sit oil pan inside old car tire and strap the engine to both siderails pulling toward the rear of truck.
Then close the tailgate against the tire. It's locked in for a off-road cross crountry run!
0.41225981712341 seconds processing time
