BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 06/07 VS 08/09 Clutch basket NEW TOPIC NEW POLL POST REPLY
DR JOE
posted April 21, 2009 07:58 PM
Just a heads up...
The 08/09 basket "WILL NOT" fit into a 06/07 motor, the gear pitch is different on the 08/09. I found that out tonight when I was trying to install the 08 basket that I bought off of eBay. The only way to make a 08/09 basket fit into your 06/07 would be to change the crank along with the basket.
So that means that the cranks are different also... So buyer beware when buying either a crank or clutch baskets for a ZX14, make sure that you get the right year to match your bike...
An easy way to tell them apart is the 06/07 gear is split, the 08/09 gear is solid. From what I can see on the parts list everything else is the same including the oil pump gear.
Just wanted to pass that along...
Doc.
posted April 22, 2009 01:00 AM
Great info Joe...
Good lookin out !!!
0.25361895561218 seconds processing time
