BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: ping Nox. NLR stuff NEW TOPIC NEW POLL POST REPLY
posted April 14, 2009 09:30 PM
ping Nox. NLR stuff
hey Doc, when you were running the 2 step, was your rpm off by half? i had dads set at 4000 to test it today, it wouldnt go over 2000, set it at 6000, wouldnt go over 3000. its not really an issue as it can be set as high as 14000 on the coarse adjustment(actual 7000) but it has me wondering. the dyna shift minder on my bike was off the same way untill i got a coil adapter, but it was from a 14 not a 12R....
NOX
PMRA / TMRC Super Street 4022
posted April 14, 2009 10:03 PM
No, mine was always dead on, still is, just have it set at 15000, so it never engages....
Now, from the tach, it is a little off..., like if I had it set at 7000, the tach would show like 7100 or 7200 maybe........
Call Sebby, he is always great help.
Good luck with it.
Don't get stupid on the two step though......., but I wish I could have launched mine at like 3000, that would have been great to try for some set ups.........
Might work in your favor.......
One of my best set ups, was launching at like 4500, did like 1.31s......., or something like that, 1.32s were more common, with that sprocket combo you guys are running.......
that was with no PC.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
NINJA12
posted April 15, 2009 06:25 AM
Nox, you always say no PC, did you use any other trick to add fuel?
posted April 15, 2009 07:42 AM
i think hes running one now, but wasnt back then
dads a bit heavier than you, but maybe we will try a lower launch rpm, we have a hair more motor, just a different clutch tune up to make it work eh?
fire spitting out the SW does look cool....
NOX
posted April 15, 2009 02:08 PM
No, sure did not.
When I did those short times, I had a stock open header on it too......
It was a bar bike then, but he lock up was tuned just right.
I ran a 9.38 in mid day on race day on a bad breakout with a free run when the other guy red lit this past weekend....., with my 9.50 set up in the bike. at 1100 ft real altitude.
I want to get back up there, and put my quick set up in it, and see what I can do up there. I have been told 9.10s are impossible on a stock motor. I think i can at least get 9.20 at that altitude.....
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
NOX
You should not have a ton of fire out the sidewinder.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted April 17, 2009 05:30 PM
not a ton, but you can see it from behind
its not mapped yet either
0.3604748249054 seconds processing time
