BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 4.5 sec @ 2-3psi oil pressure = NEW TOPIC NEW POLL POST REPLY
posted April 04, 2009 04:29 AM        Edited By: entropy on 4 Apr 2009 14:34
Whew, there are no gold specs in the oil pan, so bearings must be OK
wait a minute, the bearings are gone???
And what's all this BLACK shit????
#3 rod will probably need to be sized, I'll send it to Jim today.
had the drop in oil pressure from about 4000 rpm thru 11600 rpm in 1st gear...
Johnnycheese
posted April 04, 2009 04:51 AM
I think that oil has way too much ash content
LandspeedLarry
posted April 04, 2009 05:16 AM
Very expensive scrap, but at least the motor did not seize up and give you a Berclair Body Cast.. Glad you are OK and can race another day which turned out to be the NEXT day. Super thrash Karl & Doug=real racers. LSL
Home of the World's Fastest Naturally Aspirated motorcycles.
tcchin
posted April 04, 2009 05:40 AM
You should have used Prolong oil treatment. It works great in the commercials.
posted April 04, 2009 06:30 AM
You should have used Prolong treatment. It works great in the commercials.
OK Tim, I'll use it, but i'm kinda unsure about how to apply it???
I assume McMaster Carr carries it?
NOX
PMRA / TMRC Super Street 4022
posted April 04, 2009 07:39 AM
Hmmmm
Where have I seen that before.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
Y2KZX12R
CompetitionCNC.com
posted April 04, 2009 08:04 AM
Karl, Maybe we can weld up that #3 rod?
The wire wheel should get all the black off.
Y2KZX12R
CompetitionCNC.com
posted April 04, 2009 09:02 AM
Hmmmm
Nox,
yep you have seen it before, and likely my failure is the same as what you saw.
I have had the swinging oil pickup on 1/4mi hundreds of passes with no problem.
This time it was pointed fwd and didn't swing until i hit 2nd; logs are very clear.
But, BUT, the fault is mine not the pan/pickup design.
There was some kinda grit/shit in the swing bearing, swings stiff.
I did NOT check the swing bearing when i assembled the motor. My fault.
and expensive lesson...
posted April 04, 2009 09:04 AM
That's what I was thinking!
You and Bill have all kinda fancy machines, I sure you can fix #3, polish up the others, buy a couple bolts, GTG!!!
aliveagain
posted April 04, 2009 09:08 AM
Can you explain a little bit about the piston?Is that showing where a valve was hitting and are those pit marks from detonation?On the outside of the valve pockets,is that where people have been smoothing out to reduce hot spots?
posted April 04, 2009 09:43 AM
holy fukk.... when you break stuff, you REALLY break stuff!!
hows the crank?(does it need a trip to Marine?)
posted April 04, 2009 10:16 AM
Hey that will buff right out! maybe...
posted April 04, 2009 10:24 AM
all exh valves tapped a bit cause the bearings were GONE, not just spun, but gone.
I haven't seen detonation previously, and it is just on that one piston.
yep on the smoothing of sharp edges/ supposed hot spots, but i quit doing that smoothing, doesn't seem to make any difference either way. If i was running nitrous i would start doing the smoothing again.
The crank isn't going to Marine, too far gone. 1/2" deep gouge in #3 rod journal
it's gonna lie in ambush for the County guy who runs a brush hog through my bone-yard bushes now and again.
posted April 04, 2009 03:21 PM
LMAO... I can just see the guy... "Ho hum this job is so boring, man I can wait till tonig...(WHAM!!!!!) slighly peeing his pants, Holy Crap!!! what the hell was that??? man I have got to get a different area!!!
whitehendrix
fails!
posted April 04, 2009 08:13 PM        Edited By: whitehendrix on 5 Apr 2009 04:15
theres a bit of discoloration on #3.
might wanna hit that with some mother's and a sisal wheel.
be sure to doublecheck the torque on that main cap when you reinstall it.
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
osti33
posted April 04, 2009 09:21 PM
YIKES!!!
That is some serious carnage!
That is bushes material if I've ever seen it. Holy crap!
brendasue555
posted April 04, 2009 11:50 PM
Karl, is that what happened on that last run in Berclair? Or have you ridden it since? You would think I could have heard something that looks like that, no matter how far away I was. Ouch I hate it when that happens.
Brenda
aliveagain
posted April 05, 2009 03:33 AM        Edited By: entropy on 5 Apr 2009 12:17
Hmmmm
Nox,
a fukken expensive lesson...
How do you know the grit wasn't from the motor going or clutch fibers?
posted April 05, 2009 04:16 AM
I don't know anything for sure, but i do know the pick up used to swing freely, and it didn't swing this time.
when we took apart the motor:
aliveagain
posted April 05, 2009 09:06 AM
I see the problem now,you need to demagnetize that pick-up!
TRNorBRN6001
posted April 06, 2009 01:17 PM
Karl, like they said a little wire wheel some buffing compound and that crank and rod set are ready for e-bay!
Seriously though, that hurts! Glad you rode it out nice and smooth. Your wife and I were very concerned when we saw the mosquito fogger action.
TFA 200MPH CLUB MEMBER!
whitehendrix
fails!
posted April 06, 2009 07:18 PM
thats one hell of a paperweight.
make a lamp or table out of it!!
ZXLNT
posted April 06, 2009 09:52 PM
Crap man, that the billet crank???
posted April 06, 2009 11:33 PM
nope, weld up.
woppi
posted April 07, 2009 03:52 AM
OOOOOOOOOOOOUCH
I hate it ----------- when that happens !!!!!!!!!!!!
1st TFA Member / Austria !
2000 Limited ZX12R NOS
0.23982214927673 seconds processing time
