BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: valve shim/clearance calculator NEW TOPIC NEW POLL POST REPLY
posted March 22, 2009 01:07 AM
Awhile back I remember reading about a calculator or "chess move" tool that when given shim sizes and measured clearances, moved the shims around to give a more uniform clearance. does anyone have this that they could share? I assembeled dads cylinder head tonight and the clearances are everywhere because i didnt get any shims with the "complete" head we got, so i used ones from the old head.
oh and whats your favourite shim kit to buy? we will need at least 4 as there were 2 bad ones in my head on teardown as well as 2 bad ones in dads bad head. getting a valve job on my head will probly change a few things too.
thx guys
herbg26
posted March 22, 2009 03:20 AM
KZscott...
The shim kit I use is from Hotcams, here's a place that sell them for 79.00 bucks
http://www.cyclebuy.com/shopping/hotcams/shimkits_948.htm.
Kawasaki lover
posted March 22, 2009 08:20 AM
i use tcchin's spreadsheet.
it doesn't do chess moves but i don't think that would be overly useful for my purposes.
Tim turned me onto Honda 450 shims, same diameter as the 12, but they come in .001 increments rather than kwak .002, so i set all valves to a specific number, .008 int, .011 exh.
TRNorBRN6001
posted March 22, 2009 08:23 AM
Karl had to counsel me when I had a skinny shim disorder. lol
TFA 200MPH CLUB MEMBER!
posted March 22, 2009 08:52 AM        Edited By: dougmeyer on 22 Mar 2009 20:48
Calculator? What's wrong with the chart on page 4-21 in the manual?
Here are some tricks for those who haven't done this a lot-
I always do the head off the engine if possible, and these tips reference that method (you can also do it on the complete engine with obvious changes). Build or buy a head stand set.(Try Goodson) They're really cheap/simple. In a pinch you can set the head on a couple of pieces of 2x4, but then you end up chasing it all over the bench like a greased pig. INSTALL AND DO ONE CAM AT A TIME. I learned this the hard way on my road to becoming an expert. If you try and bolt in both cams without having them timed and working together you will bend valves or break the caps. That may seem obvious but sometimes people only think about V to P and not V to V.
Assy lube is not necessary here, just some light engine oil.
Accumulate or buy (or borrow) at least eight 250 shims. Install all eight and bolt in a cam with the sprocket installed. Turn the cam to the usual timing position with a broad rounded pry tool on the sprocket levered on the edge of the head, (like an old LARGE screwdriver) just like it would be if it was in the bike. Sometimes a gloved hand is required to help position the cam and keep it from snapping over as the nose of the cam lobes passes tdc on the buckets (ZX-12) or rockers (ZX-11). You'll figure it out. Check the valves on two of the cylinders LIKE THE MANUAL SAYS. Note the clearances and turn the cam 180 degrees. Note the clearances. Now you have eight numbers that are very large (for clearances).
Each shim size jump is .05mm or .0025". I work in inches, so I just subtract the clearance I'm looking for (let's say .008 for an inlet) from the clearance I've got, let's say .015. In this example that would be .007. So I have to close up the clearance by .007". Since each size thicker is .0025", if I divide the .007 by .0025 that is 2.8 which means I need to go 2.8 sizes larger- so I go three sizes - that's a 265.
Generally I can do this in one pass. Cam in with 250's, measure, change, re-measure and I'm good. Sometimes
I need another pass.
If you need to fudge, can't get just what you want, always err to the greater clearance (thinner shim). Clearances never grow over time, they always close up. This is especially true on a "fresh" head, i.e., one that has just been worked on or assembled.
If you are building in an effort for maximum HP and will be inspecting the engine frequently, err to the tight side (but be careful). By going tighter you maximize the area under the lift curve, but decrease V to P.
Don't be afraid to ask your favorite service mgr. to trade shims, but don't be offended if he doesn't want your 260 because he has 30......
If you have a stand and the shims at hand you can do a head in less than an hour easy and not even get your hands dirty.
That help?
Doug
posted March 22, 2009 12:17 PM
thanks for the input guys. great write up Doug
TRNorBRN6001
posted March 22, 2009 12:43 PM
Excellent info, this kind of stuff would be great on an engine build sticky.
posted March 22, 2009 12:54 PM
this type of stuff gets printed off and goes in "the book"
posted March 23, 2009 12:04 PM
just perfect.... nobody local can get the sizes i need, and the hotcams kit has too big of increments between sizes to set the clearances uniformly. im not a fan of "in the range". i have shims that are accurate to 3 decimal places(example: 2.355mm, 2.405mm), why are the dealers only accurate to 2? (same as the hot cams kits, ex: 2.35, 2.40, 2.45) i even tried honda and suzuki. it doesnt really make sense to me that the factory would have a wider range of shims than a dealer. the hot cams kit is a great deal if you need the sizes in the kit, $0.60 per shim. local guys wanted $5-$7 per shim
how much are the honda shims you get Karl?
posted March 23, 2009 12:36 PM
Tim Chin turned me onto honda CRF 450 shims, dia = 9.5mm same as a 12.
They come in .001" (+/-, they are metric) increments.
BUT be careful with all shims, if you are persnickity, measure ea one, they often times vary...
osti33
posted March 23, 2009 01:36 PM
Yes they do!!! I've been there done that.
posted March 23, 2009 01:56 PM
i had the mic out on all them! the numbers were only half there.
I asked the honda parts guy about the crf 450 shims. no luck, they just had hot cams stuff with the large increments. he couldnt order the ones i wanted either, the oem ones he could order were the same sizes as the hot cams kits. do you get your shims locally or order them online? i need 14... out of both bikes i had 2 shims that gave me the correct clearance on dads head
tcchin
posted March 23, 2009 02:38 PM
Sorry - I've been at the races, and haven't had time to forum.
Any Honda dealer can order Honda CRF450 shims (e.g., 14954-MEB-670 #252). If you can't convince your local dealer of that, you can always order them online for about $5-6 each. The nice thing about using the Honda shims is that they come in .001" increments, making the calculations really easy. Need .003" more lash? Get a shim that's three sizes thinner.
Chart? We don't need no steenking chart! (Just kidding, Doug!) I wrote the shim calculator (Excel workbook) as a sanity check, as I always seem to be adjusting valves during the wee hours of the morning, when my cognitive appreciation of "smaller-means-larger" is somewhat impaired. Lemme know if you want a copy.
I made my own cylinder head stands from Doug Fir 2x4's and red oak dowels. They're cheap and absolutely cannot damage your cylinder head. I can send you pics/plans, if you're interested.
I adjust lash on the bench too, but I use an open-ended wrench and the cam sprocket bolts to rotate the cams. The bolts are cheap and easily replaceable if they get rounded (unlikely), and you don't risk damage to the sprockets or the gasket surface like using the prying method will. If you must rotate the cams by prying, be sure to protect the gasket surface with a sacrificial scrap of wood or soft metal.
I usually measure one cylinder at a time with the cam lobes pointed 180* away from the buckets, which is not what the manual recommends. I guess I'm just too lazy to line up timing marks and remember which cylinders to check at that mark.
posted March 23, 2009 03:12 PM
better late than never Tim. ill rattle off the part number to the parts guy tomorrow and see whats up.
i would love a copy. could you email it to s_u_fire@hotmail.com plz?
i used 2x4s, and was suprised that the head didnt move all around. i think its because everything was on a towel. good idea about the dowels. im pretty sure i have a visual of what you made.
what i did to turn the cams was cut a notch in the hard plastic of an old screw driver, placing the notch in the teeth of the sprocket and just tap tap tap the sprockets around with a hammer
tcchin
posted March 23, 2009 04:08 PM
Files sent.
posted March 23, 2009 10:53 PM        Edited By: entropy on 24 Mar 2009 06:54
MRCycles has honda CRF450 shims
HIM, TAPPET (1.40)
14909-MBB-000 002 $5.82
21 SHIM, TAPPET (1.425)
14910-MBB-000 002 $5.82
21 SHIM, TAPPET (1.450)
14911-MBB-000 002 $5.82
21 SHIM, TAPPET (1.475)
14912-MBB-000 002 $5.82
21 SHIM, TAPPET (1.50)
14913-MBB-000 002 $5.82
21 SHIM, TAPPET (1.525)
14914-MBB-000 002 $5.82
21 SHIM, TAPPET (1.550)
14915-MBB-000 002 $5.82
21 SHIM, TAPPET (1.575)
14916-MBB-000 002 $5.82
21 SHIM, TAPPET (1.60)
14917-MBB-000 002 $5.82
21 SHIM, TAPPET (1.625)
14918-MBB-000 002 $5.82
21 SHIM, TAPPET (1.650)
14919-MBB-000 002 $5.82
21 SHIM, TAPPET (1.675)
14920-MBB-000 002 $5.82
21 SHIM, TAPPET (1.70)
14921-MBB-000 002 $5.82
21 SHIM, TAPPET (1.725)
14922-MBB-000 002 $5.82
21 SHIM, TAPPET (1.750)
14923-MBB-000 002 $5.82
21 SHIM, TAPPET (1.775)
14924-MBB-000 002 $5.82
21 SHIM, TAPPET (1.80)
14925-MBB-000 002 $5.82
21 SHIM, TAPPET (1.825)
14926-MBB-000 002 $5.82
21 SHIM, TAPPET (1.850)
14927-MBB-000 002 $5.82
21 SHIM, TAPPET (1.875)
14928-MBB-000 002 $5.82
21 SHIM, TAPPET (1.90)
14929-MBB-000 002 $5.82
21 SHIM, TAPPET (1.925)
14930-MBB-000 002 $5.82
21 SHIM, TAPPET (1.950)
14931-MBB-000 002 $5.82
21 SHIM, TAPPET (1.975)
14932-MBB-000 002 $5.82
21 SHIM, TAPPET (2.00)
14933-MBB-000 002 $5.82
21 SHIM, TAPPET (2.025)
14934-MBB-000 002 $5.82
21 SHIM, TAPPET (2.050)
14935-MBB-000 002 $5.82
21 SHIM, TAPPET (2.075)
14936-MBB-000 002 $5.82
21 SHIM, TAPPET (2.10)
14937-MBB-000 002 $5.82
21 SHIM, TAPPET (2.125)
14938-MBB-000 002 $5.82
21 SHIM, TAPPET (2.150)
14939-MBB-000 002 $5.82
21 SHIM, TAPPET (2.175)
14940-MBB-000 002 $5.82
21 SHIM, TAPPET (2.20)
14941-MBB-000 002 $5.82
21 SHIM, TAPPET (2.225)
14942-MBB-000 002 $5.82
21 SHIM, TAPPET (2.250)
14943-MBB-000 002 $5.82
21 SHIM, TAPPET (2.275)
14944-MBB-000 002 $5.82
21 SHIM, TAPPET (2.30)
14945-MBB-000 002 $5.82
21 SHIM, TAPPET (2.325)
14946-MBB-000 002 $5.82
21 SHIM, TAPPET (2.350)
14947-MBB-000 002 $5.82
21 SHIM, TAPPET (2.375)
14948-MBB-000 002 $5.82
21 SHIM, TAPPET (2.40)
14949-MBB-000 002 $5.82
21 SHIM, TAPPET (2.425)
14950-MBB-000 002 $5.82
21 SHIM, TAPPET (2.450)
14951-MBB-000 002 $5.82
22 SHIM, TAPPET (1.20)
14901-MBB-000 002 $5.82
22 SHIM, TAPPET (1.225)
14902-MBB-000 002 $5.82
22 SHIM, TAPPET (1.250)
14903-MBB-000 002 $5.82
22 SHIM, TAPPET (1.275)
14904-MBB-000 002 $5.82
22 SHIM, TAPPET (1.30)
14905-MBB-000 002 $5.82
22 SHIM, TAPPET (1.325)
14906-MBB-000 002 $5.82
22 SHIM, TAPPET (1.350)
14907-MBB-000 002 $5.82
22 SHIM, TAPPET (1.375)
14908-MBB-000 002 $5.82
22 SHIM, TAPPET (1.40)
22 SHIM, TAPPET (1.425)
22 SHIM, TAPPET (1.450)
22 SHIM, TAPPET (1.475)
22 SHIM, TAPPET (1.50)
22 SHIM, TAPPET (1.525)
22 SHIM, TAPPET (1.550)
22 SHIM, TAPPET (1.575)
22 SHIM, TAPPET (1.60)
22 SHIM, TAPPET (1.625)
22 SHIM, TAPPET (1.650)
22 SHIM, TAPPET (1.675)
22 SHIM, TAPPET (1.70)
22 SHIM, TAPPET (1.725)
22 SHIM, TAPPET (1.750)
22 SHIM, TAPPET (1.775)
22 SHIM, TAPPET (1.80)
22 SHIM, TAPPET (1.825)
22 SHIM, TAPPET (1.850)
22 SHIM, TAPPET (1.875)
22 SHIM, TAPPET (1.90)
22 SHIM, TAPPET (1.925)
22 SHIM, TAPPET (1.950)
22 SHIM, TAPPET (1.975)
22 SHIM, TAPPET (2.00)
22 SHIM, TAPPET (2.025)
22 SHIM, TAPPET (2.050)
22 SHIM, TAPPET (2.075)
22 SHIM, TAPPET (2.10)
22 SHIM, TAPPET (2.125)
22 SHIM, TAPPET (2.150)
22 SHIM, TAPPET (2.175)
22 SHIM, TAPPET (2.20)
22 SHIM, TAPPET (2.225)
22 SHIM, TAPPET (2.250)
22 SHIM, TAPPET (2.275)
22 SHIM, TAPPET (2.30)
22 SHIM, TAPPET (2.325)
22 SHIM, TAPPET (2.350)
22 SHIM, TAPPET (2.375)
22 SHIM, TAPPET (2.40)
22 SHIM, TAPPET (2.425)
22 SHIM, TAPPET (2.450)
22 SHIM, TAPPET (2.475)
14952-MEB-670 002 $5.82
22 SHIM, TAPPET (2.500)
14953-MEB-670 002 $5.82
22 SHIM, TAPPET (2.525)
14954-MEB-670 002 $5.82
22 SHIM, TAPPET (2.550)
14955-MEB-670 002 $5.82
22 SHIM, TAPPET (2.575)
14956-MEB-670 002 $5.82
22 SHIM, TAPPET (2.600)
14957-MEB-670 002 $5.82
22 SHIM, TAPPET (2.625)
14958-MEB-670 002 $5.82
22 SHIM, TAPPET (2.650)
14959-MEB-670 002 $5.82
22 SHIM, TAPPET (2.675)
14960-MEB-670 002 $5.82
22 SHIM, TAPPET (2.700)
14961-MEB-670 002 $5.82
22 SHIM, TAPPET (2.725)
14962-MEB-670 002 $5.82
22 SHIM, TAPPET (2.750)
14963-MEB-670 002 $5.82
22 SHIM, TAPPET (2.775)
14964-MEB-670 002 $5.82
22 SHIM, TAPPET (2.800)
14965-MEB-670 002 $5.82
22 SHIM, TAPPET (2.825)
14966-MEB-670 002 $5.82
22 SHIM, TAPPET (2.850)
14967-MEB-670 002 $5.82
22 SHIM, TAPPET (2.875)
14968-MEB-670 002 $5.82
22 SHIM, TAPPET (2.900)
14969-MEB-670 002 $5.82
22 SHIM, TAPPET (2.925)
14970-MEB-670 002 $5.82
22 SHIM, TAPPET (2.950)
14971-MEB-670 002 $5.82
22 SHIM, TAPPET (2.975)
14972-MEB-670 002 $5.82
22 SHIM, TAPPET (3.000)
14973-MEB-670
whitehendrix
fails!
posted March 24, 2009 07:08 PM
Tim, Doug... you're absolutely invaluable.
Doug, do you mind my "stealing" your writeups and posting then on another forum? you're given full credit as well..
awesome shit here.
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
posted March 24, 2009 09:35 PM
Where are you putting them? I'd like to check it out.
Doug
posted March 25, 2009 12:01 PM
thank you Tim and Karl!
Tim, my visual was quite different. i thought you were using the dowels to fit in the head like the factory dowels that fit in the head/block. you put the head at an angle to make checking the clearances easier eh?
Nice list Karl. Ive been busy with my truck, so i have been away from the bikes, gotta check some things out tomorrow locally
tcchin
posted March 25, 2009 01:34 PM
We were wondering where you went. We were afraid something bad happened with you and the DPTW Barbies.
With the dowels in a Y-configuration, you can put the head at any angle you want, even upside-down. They make good porting stands, too, as the head can be held in just the right position so your head and neck don't have to.
How'd you make out with the valve lash spreadsheet? Are those some mondo formulas or what?
posted March 25, 2009 02:53 PM
busy making a little truck a big truck lol. no GB's involved, ill leave it up to you to get DP action shots
i could have put those stands to good use porting! i may make a set...
great spreadsheet! very simple to use
whitehendrix
fails!
posted March 25, 2009 06:34 PM
Doug
that would be www.kawispeed.com
posted March 26, 2009 12:21 AM
just incase you were curious, this is my truck project.
old mans F150 with add a leafs and cranked torsion bars on 33s vs my Dakota with 6 in lift on 38s almost done(untill i upgrade the drivetrain and put on a stand alone efi controller after the bikes are built)
0.35053491592407 seconds processing time
