BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: suprise in the mail today (Hindle) NEW TOPIC NEW POLL POST REPLY
posted February 19, 2009 11:22 AM        Edited By: KZScott on 19 Feb 2009 20:42
I knew it was the pipe, but I thought i was getting a used SS system for some reason. Wrong! i unwrapped the header first from its bubble wrap and i think my eyes just about popped out of my head lol
the whole thing weighs 10 pounds going by the bathroom scales.(just did 3 more back to back tests which are accurate to about .5 pound) it was on a stock motor no power adders, so im sure i can make it look like a rainbow when i give it a shot of nitrous :P
posted February 19, 2009 11:48 AM
Very nice Scott! I also have a new exhaust coming today...
posted February 19, 2009 12:45 PM
both of us making the switch from Muzzy to Hindle eh Shane? Muzzy makes great pipes, but the Hindle (and Brock/Hindle) seem to be just a little bit better. I think the larger diameter tubing on the Hindle after the initial section (which is the same size as Muzzy street system) will respond better to nitrous. and Ti is obviously lighter! i may shorten the can to get further weight savings. im thinking the lower section with the race tech sticker wouldnt be missed. I think I could get it close to the Alien head weight spec for the 14 of 9 pounds.
I kinda have map support too, allthough nothing like Brock. I have VH's map that made 182 hp on a stock motor. i richened the top end of the map by roughly 10% by comparing the map i used for 07 and the map i made based on log files to try for 09(if i had of kept the Muzzy). Ill further tweak it with the logger as soon as everything is back together. Im hoping for 4-5mph improvement in the 1/8 and 1/4 NA
450 cad shipped. I love buying used stuff
posted February 19, 2009 02:16 PM
Looks like his timing was retarded! Hence the Extra heat and blueing! You never said how much?
posted February 19, 2009 03:33 PM
i have no idea what map or timing adjustments he had made. i have have YOUR map though
posted February 19, 2009 04:20 PM        Edited By: Shane661 on 20 Feb 2009 00:21
Yeah, Brock/Hindle came today:
Didn't think I would switch from the Muzzy, but the Brock's is 5 lbs. lighter!
whitehendrix
fails!
posted February 19, 2009 08:00 PM
soooo nice.
jealous.
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
osti33
posted February 19, 2009 11:02 PM        Edited By: osti33 on 20 Feb 2009 07:03
Scott,
Are you sure that the header part of the pipe is Ti? It sure looks like stainless to me. Hindle uses a thinner wall tubing than Muzzy does. That could be your weight difference. The can is Ti but I would double check the header before you buy a Ti bung.
tshultz
posted February 20, 2009 08:42 AM
Scott,
That's a good question i just welded a bung to my Hindle exhaust and had no problems i just assumed the pipe was SS and not Ti.
posted February 20, 2009 10:28 AM
I didnt think that an SS header would turn all those colours??? the mid pipe is a diff colour though....?? how do i check? colour of sparks with a dremmel on an inside edge?
posted February 20, 2009 02:35 PM
ok, i did the spark test. only the can is Ti(white sparks) the header and mid pipe are SS (orange sparks). Ti bung problem solved...
thx for the heads up Ryan
osti33
posted February 20, 2009 03:10 PM
Good deal. Glad you got it sorted out before you ordered a Ti bung that you didn't need. Those Ti bungs are kinda pricey. I think I paid like 50 or 60 bucks for mine.
posted February 20, 2009 03:27 PM
and a steel M18x1.5 nut is about $2 and i can braze that on myself
Bawls
re-learning to ride
posted February 24, 2009 07:37 PM
I got my new brocks system last week, and. Am loving it. I went with the shorty gen3 system which is probably a lot like what you're looking to do to your pipe. It's 14" instead of 20.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
Bawls
re-learning to ride
posted February 24, 2009 07:46 PM
here you go. not meant as a thread jack, but if you would like i can take some more pics.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
posted February 24, 2009 11:10 PM
yeah, i think the can would look better short like that. and would weigh less
im just not sure i want to cut it . ill probly tape it off and use a dremmel cut off wheel, then file it flat. unless there are better ways?
posted February 27, 2009 02:34 AM
Scott looking at your pipe I realized that it is an "Original" Step Tube Hindle! One of the first 25 made! How do you know? After the first look at Shanes pipe and see that the Collector where the 4 go into the 2 is Separate and yours is welded into 1 piece like mine was!
Bawls
re-learning to ride
posted February 27, 2009 06:01 AM
is that not because of the fact that shanes is a brocks by hindle, and scott's is just a hindle?
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
posted February 27, 2009 07:47 AM
No, Has nothing to do with Shanes! I got one of the first 5 they made and a friend got one later (Bergie) and it was made without the extra welding. The difference between Brocks and Hindle you cannot see because it is in the Divider Plate in the "2" Section!
posted February 27, 2009 02:47 PM
thats pretty cool, one of the first 25! i got it from a guy in ontario, so i have no doubt it was bought directly from Hindle in ontario. Harry (northernkaw) had it on a bike then sold it to a friend. i got it from the friend as he switched to an all Ti Arata i believe
posted February 28, 2009 01:27 PM
The Ti-Arata is a lot Prettier Pipe and Beautiful Welds, but Beauty is as Beauty does and Nothing is (on A verage) better than what you have!!
posted February 28, 2009 02:05 PM
you used this pipe for your nitrous bike right? do you remember offhand what fuel pressure and jet sizes you used for 100 and 120 hp? also what fuel/afr and amount of retard?
zx12dak
posted March 02, 2009 05:12 PM
Nice pick up Scott !!!!
posted March 03, 2009 05:45 AM
I just lost a paragraph I wrote! The long an short is 11 to 1 A/F and use a simple system that does not rely on the idiot designer which in my case is ME! I must set the NOS & Fuel pressure for each power setting I plan to use. I did a LOT (A WHOLE LOT) of flow testing to get these figures. The problem is, I forgot to set a fuel pressure once and destroyed my engine!
I use a Muzzy fuel Pump and a device I made to take the fuel from the return side through a bypass Fuel pressure regulator so that I can use a fixed size Fuel and NOS Jet!
0.28207802772522 seconds processing time
