BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: wanna have FUN?: change out yr main wiring harness! NEW TOPIC NEW POLL POST REPLY
posted February 03, 2009 03:19 AM
yep, its a ball!
And to add even more joy to the project, i need to tap into it for data logger, shift light, gear indicator, muzzy air shifter.
reminder:
EITHER put out the cig OR hook up the fuel hoses before turning on the key for testing
next i will change out the ign switch and the sub harness for the coils.
My 9 YO wires and connections got undependable, time to upgrade...
posted February 03, 2009 04:07 AM
that does sound like fun :S ....dyno next wknd?
posted February 03, 2009 04:20 AM
I have a standing appointment, every Sat at 11am
Currently working on assuring that ign voltage is clean and to spec, right now my coils were getting low voltage. I wanna get it to spec and see if it makes any difference.
posted February 03, 2009 05:25 AM
Andy must love you lol
ahh that may be where your 20hp is hiding? thought about trying an aftermarket cdi?
posted February 03, 2009 05:48 AM
nope, no aftermarket CDI (yet), just trying to get back where i was
NINJA12
posted February 03, 2009 07:19 AM
Karl, you are my inspriation.
The list of stuff you find or fix makes me understand how small my problems really are.
I put a harness on the 14 chasing a wiring problem. It's not that bad, 2 hours max.
Thanks big guy.
posted February 03, 2009 02:49 PM
Thanks big guy.
hey Gerard,
yep, just running the harness is not real bad, cutting into it and adding all that other stuff just adds a bit of time. Firing it up and fixing the fukups is inevitable.
You ARE coming down to the Texas Mile one o' these days, eh?
Hell, i drove all the way to Memphis just to meet you!
Remember, you are the guy whose curiosity and questions never stop; that helps me keep asking questions.
Karl
whitehendrix
fails!
posted February 03, 2009 08:21 PM
OOo electrical. so fun!!
i don't mind this since i have a degree in it, and am used to PLC and robotics systems incorporating thousands of wires and hundreds of ins and outs and networked controllers.
a simple 12V system is a walk in the park!!
i'm in the middle of some retrofitting and mods to my harness now! i love how kawi used 14 and 16 gauge wire for a 30 amp circuit (alternator output)
i'm routing the main power to a relay instead of thru the keyswitch. and i'll be switching the form 1C relay for the starter control circuit for a solid state one.. try to boost reliability a bit on my beast.
wiring.. goooood times.
occasions. - ZRXDean
ill never own a busa unless
ill sell it -KZScott
posted February 04, 2009 07:49 AM
new harness is in, although i still need the sub-harness with coil plugs (backorder).
gained aa lil under.5V to the coils, still under spec.
Found that the ign switch is eating .4V, that will be replaced tonight.
It was a joy to remove the ign switch,... But, thanks to the Cheeseman's advice, I avoided using the big ball peen hammer.
Like fugging pulling teeth to get this ole wreck's electrics back to spec.
whitehendrix
fails!
posted February 04, 2009 06:49 PM
i've always thought of the kawi electrical system to be one of the most gruesome and hideous things ever devised.
thus the reason i'm changing so much in my harness. the bike pulls damn near 15A with EVERYthing on and running.. the batter is 12A/hr.. THAT makes sense eh? at least the alternator puts out 30A to take the load, but transmitting across 14 and 16 Ga wire? tisk tisk.
good luck bossman! sounds like you're justifying that pain-in-the-ass work so far be finding and killing voltage drops.
posted February 04, 2009 10:55 PM
those anti tamper bolts arent fun. i took my switch off when i stripped the upper triple paint off (it was chipped off in a few places). i drilled the heads off then put normal bolts back in.
once you get it making full power again, I think you should try a Dynatek ARC-2 because of your super high CR. This CDI ignition is capable of producing over 50,000 Volts at the spark plug, and has the highest spark energy of any CDI on the market. It is designed to optimize the ignition of modified vehicles, providing the strong spark needed to develop peak power for turbocharged, nitrous oxide and high compression applications
Testing has shown a 3 horsepower increase on completely stock Hayabusas. A higher increase of up to 10 horespower is expected on turbo/nitrous applications
Im getting one mainly for the built in 2 step, but it should help running a big shot of giggle juice
posted February 05, 2009 03:30 AM
One o' these days i might try the CDI setup, but in no hurry.
basics - basics - basics
Y2KZX12R
CompetitionCNC.com
posted February 05, 2009 04:57 AM
Hey, just to let you guys know.
Sims Motorsports has come out with a 24volt setup for starting AND CHARGING any bike that needs 24v to start. It charges both batteries and starts on 24volts without any switches etc.
They should be available very shortly. Karl, If you want one now to add in I can get you an early production one.
Y2KZX12R
CompetitionCNC.com
TRNorBRN6001
posted February 05, 2009 06:58 AM
Karl, After you finish your testing and would like to try the CDI just for grins on one of your Saturday standing appointments, just let me know. I have one hanging out right now with the plug and play ZX-12 harness for it.
Curious Jim, how much do those Sims 24volt setups run.
TFA 200MPH CLUB MEMBER!
posted February 05, 2009 09:42 AM
cool! how big are they?
where would you mount it?
I don't need one now but maybe later.
Gary,
If you have a harness & CDI set up for a 12, mable i could try it.
Have you tried it?
TRNorBRN6001
posted February 05, 2009 10:03 AM
Nope, have not tried it yet. It will be for the new 12 motor and surface gap plugs. Let me know, any time and I'll ship it to you.
Gary
Y2KZX12R
CompetitionCNC.com
posted February 05, 2009 03:58 PM
Karl, its a very small harness with a dpdt relay and some other small stuff. not very big.
Y2KZX12R
CompetitionCNC.com
whitehendrix
fails!
posted February 05, 2009 07:10 PM
oh, my tip o the day..
for those pesky anti-tamper screws on the ignition switches, slot the top with a 1" Dremel cutoff wheel. they'll come right out with a flat screwstick then AND they're now reuseable.
0.22786402702332 seconds processing time
