BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: PC3r: you ole trickster, you! NEW TOPIC NEW POLL POST REPLY
posted January 22, 2009 02:16 AM        Edited By: entropy on 22 Jan 2009 10:51
Although I have had issues in the distant past, my lil Lenovo laptop has been flawlessly hooking up to my PC3r for months.
then outa the blue, the laptop does not see the PC3r??????
hmmmmmm....
It refuses to recognize the PC3r for a week,
then outa the blue it sees it again.
No changes to nuthin.
WTF??
shiphteey
posted January 22, 2009 05:14 AM
Maybe its a sign....maybe we should both step up to the newer ones...I'm just broke.
Gemini Motorcycles
posted January 22, 2009 05:38 AM
hey Ship!
I don't think anything is broken, just every once in a while the PC doesn't see the PC3r, i have also seen it happen on my dyno guy's PC.
He was having a bitch of a time connecting to Powercommanders of different bikes, then mysteriously the problem went away.
I betcha that we just need to click on something when it happens????????
NOX
PMRA / TMRC Super Street 4022
posted January 22, 2009 06:40 AM
Check the portals
or whatever they are called......, I have that issue sometimes.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted January 22, 2009 08:22 AM
i allways found it worked better if you turned the pc control center on after it was plugged into the bike and the bike was running. and the port was set to automatic. sometimes it wouldnt connect if the PCCC was turned on before the bike was fired up
posted January 22, 2009 12:59 PM
yep, my experience is like yours, but i want it to reliably fire up when the bike is off.
My "work on the bike" hours usually start at 1am
my wife & neighbors seem to notice when i start it at 2am...
tcchin
posted January 22, 2009 01:56 PM
The PC3r uses an RS232 interface, not USB, right?
posted January 22, 2009 02:00 PM
have you thought about sticking a car/truck muffler over the tip of the pipe for those late night fire ups? might make the sound low enough to avoid noise complaints? its not a fix for the pc issue, but may be a way around it. get some of that flexable tubing like in a dyno room and run it to a muffler from a half ton?
posted January 22, 2009 02:03 PM
if RS232 interface = 9 pin straight thru serial cable then yes
Megabyte
posted January 22, 2009 05:10 PM
+1
2000redrocket
posted January 25, 2009 02:30 PM
entropy i thought got the ridge mod? why are you messing with the power commander?
also the motty afr tuner sounds like a reason to chuck the power commander. what do you think???
posted January 26, 2009 12:11 AM
i have a ridge modded ECU but only use it for extended rev limit.
My issues are around motor config, and don't want to introducing variables assoc w/the ECU at this time. My PC3r is very predictable wrt changing AF & ign timing so i am staying with it for now.
I don't know anything about the Motty unit; doing data logging with an Innovate system.
Do you know the sample rate of the Motty?
0.21654796600342 seconds processing time
