BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: 5 pound bottle brackets NEW TOPIC NEW POLL POST REPLY
posted December 09, 2008 11:10 AM
I want to get rid of my 2 pound nitrous bottle in the tail and mount a 5 pounder on the swingarm. does anyone know of a nice aluminum bracket?(preferably not too expensive or too much bling) all i can find are the 2 steel ones you see in cars. someone has to know how to mount a 5 pounder on a bike.... Im not opposed to making something, but I dont have a tig...
thx!
Gixx1300R
posted December 09, 2008 11:33 AM
That is a very large bottle. Why not get another 2lbs or 2.5lbs and install it in front of the rear wheel if you are extended? That way you will have a total of 4 or 4.5 lbs.
posted December 09, 2008 02:03 PM
too much hassle getting them filled around here, plus my 2 pounder is going on dads bike. I want to get 2 runs out of a bottle with a 120 shot. 90 hp used a pound per pass from 2nd gear on, and i want to spray in first with a progressive controller this yr
Gixx1300R
posted December 09, 2008 02:04 PM
ok gotacha
posted December 09, 2008 02:18 PM
keeping flow consistant for 1 mile runs is another goal. im told two 2.5s dont compare to a single 5
Gixx1300R
posted December 09, 2008 02:22 PM
That has always been a problem using systems that use 4 NItrous Jets. They run out of N20 quicker and drop N20 pressure faster.
TRNorBRN6001
posted December 10, 2008 06:13 AM
KZ, how about making a plate to mount where your rear peg hanger mounts
and then use two Pro-werks brackets for the 5 pound bottle. I know a ZX-12
and Busa guy that do this. The Bottle snugs up right behind your thigh and
leg. Sorry, don't have any pictures.........but I could probably get some for you
this weekend. For some reason I only have pictures showing the exhaust side.
You will just have to make a little offset so it does not tag your chain guard or
swingarm. I have seen it tap the chain guard into the tire and shave a brand
new tire. LOL
TFA 200MPH CLUB MEMBER!
Halvefast
posted December 10, 2008 08:12 AM
Here is Dr.Gary with his Scuba Tank
ECTA Ohio Mile 195.132mph
posted December 10, 2008 10:04 AM
thx for the info and pic guys! those Pro-werks brackets look like just what im after! Ive got lots of room in front of the wheel and would prefer to keep the bottle from hanging off of the side of the bike. I still may put them on a plate however so i can try to angle the bottle correctly.
TRNorBRN6001
posted December 10, 2008 11:50 AM
Thanks Rich, never really seen it from that angle. I think I was running around 265lbs back then. Dang I need to loose at least 20-30lbs before the start of this new season.
Mr. Guy Caputo runs a 5'er in is arm, give him a call I am sure he could point you in the right direction.
posted December 10, 2008 12:50 PM
They are actually running 10 pound bottles nowadays! Jim Owen ZX12R 219 MPHRecord Setter mounted one in the tail section and mounted a plate for his tail light and license plate and Seldon Seen Slim mounted his in the frame there the Gas tank used to be and then has a small tank on top where the old tank was!
Guy Capulto from Toledo Ohio 225 MPH NOS Record had a 2.5 pound bottle behind his legs.
Me I have a 5 pound in my tail section and Bottle heater along with a 20 Amp Battery (Takes a little modification of the stock battery location and you gain 6 Working Amps!) It can be adapted into stock tail sections specially the longer ones!
TRNorBRN6001
posted December 10, 2008 05:35 PM
Rich is that your Blue 14 in the background of the pic? And look you can just see MadMikes front fender and Nose poking out.
10 Pounders!!!! Thats crazy big!!
Mr. Hill which Maxton event are you shooting for? I'd like to be there when you run.
I hear SSS is going to be running some major juice on his as well. I'd like to see that old silver 12 running strong too!
Halvefast
posted December 10, 2008 05:42 PM
Nope that one still has stk pipes on it still.
If I remember right I saw that nose (MM) sticking straight up in the sky
on one pass must have hit the button a litlle to soon.
posted December 11, 2008 05:26 PM
Mikes paint is really something else awesome looking 12
0.24974989891052 seconds processing time
