BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: progressive nitrous NEW TOPIC NEW POLL POST REPLY
posted November 29, 2008 02:42 AM
progressive nitrous
whats a good inexpensive controller? Im looking at the Schnitz 2 dial... I really dont want to pulse the solenoids a lot, but i dont really see many options. thinking of trying a 100 shot(maybe more? 120?) in my wet kit. I have a Schnitz rpm window switch set to activate nitrous in second gear. if i wait till second i shouldnt need very much ramp time right? would I even need the controller? I know i should start spraying in first to get the most out of it, but I dont want to pulse the solenoids much....I have a dry shot i could use in first gear. is there a way to turn that off in second when the wet kit turns on ? a couple relays?
thx
posted November 29, 2008 05:52 AM
My advice is to keep it as simple as possible.
I would also consider what advantages ramping the nitrous might have for engine longevity. How quickly do you want your cylinder pressures and temps to rise?
I'm not a nitrous expert, obviously...but sometimes less is more. I would use a smaller progressive shot and maximize it's potential. You have an 8 second capable bike without the spray.
posted November 29, 2008 09:39 AM
Schnitz box
posted November 29, 2008 02:00 PM
I like trying to complicate stuff lol
you make a good point about the cylinder temp/pressure. no wonder the turbo guys get away with so much power....
I know i change my mind more than anyone, but maybe it would be best to run the progressive wet shot from first gear. dad wouldnt object to the dry kit going on his bar bike. we could hit that in first with the bars easy....
whats a good starting point for the 2 dial on a 100 shot? 20% with a 1.5 sec ramp??
SteddyTeddy
posted November 30, 2008 10:22 AM
I have a like new Edelbrock progressive that may be up for sale in a couple days. I offered it to someone but haven't heard anything back yet.
posted November 30, 2008 03:33 PM
thanks Teddy, but I have a Schnitz 2 dial on the way. there was one listed for sale on psychobike. any ideas on how it should be set up for % and ramp time?
almost_les
posted November 30, 2008 05:18 PM        Edited By: almost_les on 1 Dec 2008 01:18
200% start, 0.0 sec. build time
SteddyTeddy
posted November 30, 2008 07:00 PM
I have mine setup at 10% and about 2sec ramp time with a 50 shot but I'm no pro.
posted December 01, 2008 01:15 AM
reminds me of the dynotune kit(you get double the hp they say you do)
you spray in first Teddy?
woppi
posted December 01, 2008 02:08 AM
the 2dail works fine !!!
the 5 dial --- also easy -- better to adjust !!!!!!!!!!
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
posted December 01, 2008 03:46 AM
got a Schnitz 2 dial on the way
SteddyTeddy
posted December 01, 2008 04:53 AM
I had mine hooked on a WOT switch. It was spraying by the 60' mark.
0.29853487014771 seconds processing time
