BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: This is a bad clutch hub - HmmmKaaaaay?? NEW TOPIC NEW POLL POST REPLY
BA
posted September 05, 2002 08:52 PM
This is what I was greeted with during my recent clutch plate replacement.
Now, I go in and pull out my plates and inspect them all about once a month, sometimes swapping out bad ones for better ones. I didn't imagine that my HUB would be this bad!!!
I had taken notice of some 'slight' (or so it seemed) indentations, but didn't think much of it.
When I took the whole hub out and got a better look at the whole thing on a bench, this is what I was greeted with!!!!!
Just imagine the same picture, for all 360 degrees around the hub!!
Guess 7000 hard miles and a few hundred runs take their toll on that poor puppy.
Makes it really difficult for the plates to SSLLLLIIIIIIDDDEE in and out! Bad for consistent launches too!
Live and learn.......
Anyone else seen this on theirs?
your car is slow
Fuck Nitrous...Got Boost?
posted September 06, 2002 09:50 AM
Wow....
Makes me wanna go pop off the clutch cover and take a closer look :/
Do not taunt happy fun ball!
RAC4IT
Bergie
posted September 06, 2002 09:52 AM
I dunno dude I'll have to check mine tonight! Looks like they might need to make a billet hub too!
krexken
posted September 06, 2002 01:54 PM
I noticed the same thing while working on a friends 12 a while back. His billet basket was in the same shape.
BA
posted September 06, 2002 06:36 PM
The steel 'teeth' of those steel plates just seems to 'take it's toll' on the ol inner hub, which isn't of 'billet quality'.
Just seems like the inner hub is made a little too soft.
A big name in racing told me that he used to replace his inner hub 3 times a year!! (8.0's at 180 or something in that area)
aliveagain
posted September 06, 2002 06:44 PM
I wonder if nickel plating would slow down the wear?
RAC4IT
Bergie
posted September 06, 2002 10:13 PM
I just swapped my clutch and inspected mine... although you can see the marks if you run a blade across them it doesn't appear to hinder the movement of the plates (..yet) but it's definitely a wear item to keep an eye on. Thanks for the heads up BA another great tech post to be aware of.
NINJA12
posted September 07, 2002 09:21 PM
You can buy that separate from Muzzy.
I think it was $100.
I wonder what would happen if you installed the clutch with the extra steel loaded first, it would offset all the indentions. MAYBE.
ra12r
posted September 08, 2002 03:22 PM
You would lose the friction equal to one fiber in your clutch pack.....
NINJA12
posted September 08, 2002 07:41 PM
No, many of us add a steel to the muzzy pack to get it back to full height.
I suggest we move that steel all the way to the inside.
kcadby
posted September 11, 2002 11:03 AM
That's a common site on hubs that are raced...or have lots of miles...nothing lasts forever ...
ra...no friction is lost by adding a steel plate...
I agree that adding the steel plate also moves all the plates and will help hub-life...somewhat...
BA
posted September 11, 2002 05:48 PM
agreed. best to add that extra plate a little sooner than the 10000 miles and 200 runs or so that I have. (if only I would have known!)
Ninja12 - you're right also. having the plate as inner-most as possible would 'help' more of the hub and stack than putting it in the middle.
posted September 12, 2002 06:06 PM
And this is a bad basket...Glad it wasn't a billet! Maybe I can get some $$$ for it as a core?
BA
posted September 12, 2002 08:03 PM
HOLY CRAP DUDE!!! It's BENT! WTF!
Is that damage and the gouges on the backside from when you lost a rod? That was you right, that lost the rod? (the 1270?)
That's one nasty piece of hardware!
posted September 13, 2002 06:33 PM
That's right, chunks got in there and did bad things!
0.24296402931213 seconds processing time
