BIKELAND > FORUMS > DRAGBIKE ZONE.com > Thread: Real Street Spraybar NEW TOPIC NEW POLL POST REPLY
Gixx1300R
posted November 21, 2008 01:18 PM
posted November 21, 2008 01:22 PM
Is that for a wet system...or two-stage dry? Or both?
posted November 21, 2008 01:36 PM
looks like 2 stage dry to me. if you look at how a fogger nozzle is designed you see the difference.
Stuart Racing
N.H.R.A . Dragracing.
posted November 21, 2008 01:46 PM
Looks like a wet syst.
Gixx1300R
posted November 21, 2008 01:47 PM
It's a 2 stage Dry System
posted November 21, 2008 02:01 PM
on a wet system, the nitrous is basically blown thru the trickle of fuel (at an angle so it cant go backwards against the fuel)so it mixes evenly and atomizes the fuel. if you just have the fuel on with a wet system its like turning on the kitchen sink really low. if that above spraybar was used as a wet kit you may not even get any fuel to come out since the nitrous is under so much more pressure, and the bar would have to have some fancy machining internally to get it to work. and if the lines were backwards it wouldnt work. look at a fogger and you will see what i mean
Gixx1300R
posted November 21, 2008 02:08 PM
Scott is exactly right. The above spraybar is for a 2 stage dry system only. This is my Wet Spraybar. See the difference.
posted November 21, 2008 02:24 PM
how well is the fuel atomized without running nitrous thru it? your wet spray bars must run a really high fuel pressure?
Gixx1300R
posted November 21, 2008 03:06 PM
atomomizes just fine. has gone 7.70s so far.
Stuart Racing
posted November 22, 2008 10:58 AM
Aaaah I see.....
posted November 22, 2008 01:18 PM
got a pic of the wet bar in action? i know you have tons of the dry bar
Gixx1300R
posted November 22, 2008 01:19 PM
Sorry No, But I will have some soon. Kinda dangerous to vent high pressure fuel into the atmosphere.
posted November 22, 2008 01:24 PM
haha just dont aim it at someone smoking:P
Gixx1300R
posted November 22, 2008 01:37 PM
LOL,just remember that I would have to connect the fuel pump and solenoid to a 12v power source in open air. Fuel and spark at that point would not be a good thing.
0.2613251209259 seconds processing time
